RX V5 upload error
Hi Werk
This morning I tried to update the software to V5. The TX & WD stations as far as I can tell went ok but the RX comes up with the following error and the upload failed, I have now reverted back to the original setup : -
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\rich2\OneDrive\Documents\Arduino\WeatherDuino_Pro2_PLUS_v5.0_RH_20171229\WeatherDuino_Pro2_PLUS\v5.0\software\RX software\WeatherDuinoPro2Plus_RX_v500_b001\WeatherDuinoPro2Plus_RX_v500_b001.ino:596:0: warning: "TFT_DARKGREEN" redefined
   #define TFT_DARKGREEN       0x0100
In file included from C:\Users\rich2\OneDrive\Documents\Arduino\WeatherDuino_Pro2_PLUS_v5.0_RH_20171229\WeatherDuino_Pro2_PLUS\v5.0\software\RX software\WeatherDuinoPro2Plus_RX_v500_b001\WeatherDuinoPro2Plus_RX_v500_b001.ino:56:0:
C:\Users\rich2\OneDrive\Documents\Arduino\libraries\TFT_ILI9341/TFT_ILI9341.h:167:0: note: this is the location of the previous definition
 #define TFT_DARKGREEN   0x03E0      /*   0, 128,   0 */
C:\Users\rich2\OneDrive\Documents\Arduino\WeatherDuino_Pro2_PLUS_v5.0_RH_20171229\WeatherDuino_Pro2_PLUS\v5.0\software\RX software\WeatherDuinoPro2Plus_RX_v500_b001\D_TFT.ino:669:14: warning: character constant too long for its type
         #if (Language == 'cs_CZ')
C:\Users\rich2\OneDrive\Documents\Arduino\WeatherDuino_Pro2_PLUS_v5.0_RH_20171229\WeatherDuino_Pro2_PLUS\v5.0\software\RX software\WeatherDuinoPro2Plus_RX_v500_b001\D_TFT.ino:669:26: warning: character constant too long for its type
Sketch uses 81206 bytes (31%) of program storage space. Maximum is 253952 bytes.
Global variables use 4801 bytes (58%) of dynamic memory, leaving 3391 bytes for local variables. Maximum is 8192 bytes.
An error occurred while uploading the sketch
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Hi Rich,
Thank you for being trying to install the latest WeatherDuino Pro2 Plus software suite.
The issue reported (upload aborts) may not be related with the software, as it compiles fine, however I decided do make some changes to reduce those compiler warnings. Also there are new version of the WD software, which now allow the use of a local T/H sensor.
Please download the updated software package (2018-01-01). Sorry for any incovenience caused by the previous release.
(01-01-2018, 21:13)Werk_AG Wrote:  Hi Rich,
No inconvenience Werk, I regard it as part of the process improving the system Big Grin
I'll download the new version tomorrow and test.
I've uploaded the updated software on all devices (RX, TX & WD) and they all work fine.
I did get some minor errors while compiling the WD software but it didn't stop it uploading.
I have attached the errors.
Rich, thank you for the update.
Hope you enjoy being using it.
Personally I noted a fairly improvement on the RF performance since using the RadioHead library.
The "errors" reported are just compiler warnings, any of them (all are related to a specific function) will prevent the system from working perfectly.
Once again, thank you.
Werk
As suggested I decided to upgrade to v5 Pro2 Plus but received an error upgrading the TX module. Copy of the error file is attached
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P" C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\JBA\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path C:\Users\JBA\AppData\Local\Temp\arduino_build_273504 -warnings=none -build-cache C:\Users\JBA\AppData\Local\Temp\arduino_cache_438485 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v5.0\software\TX software\WeatherDuinoPro2_Universal_TX_v5_20012018\WeatherDuinoPro2_Universal_TX_v5_20012018.ino C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\JBA\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10805 -build-path C:\Users\JBA\AppData\Local\Temp\arduino_build_273504 -warnings=none -build-cache C:\Users\JBA\AppData\Local\Temp\arduino_cache_438485 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v5.0\software\TX software\WeatherDuinoPro2_Universal_TX_v5_20012018\WeatherDuinoPro2_Universal_TX_v5_20012018.ino Using board 'nano' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr Using core 'arduino' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr Detecting libraries used... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\preproc\ctags_target_for_gcc_minus_e.cpp" C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v5.0\software\TX software\WeatherDuinoPro2_Universal_TX_v5_20012018\WeatherDuinoPro2_Universal_TX_v5_20012018.ino:43:59: fatal error: RH_ASK.h: No such file or directory #include <RH_ASK.h>                // library for RF RX/TX                                                           ^ compilation terminated. exit status 1 Error compiling for board Arduino Nano.
As you can see i have the latest Arduino software and re downloaded v5 this morning
Hi Jim,
Seems you forgot to read the change log  Smile
Quote:Change Log:
WeatherDuino Pro2 PLUS RX v5.0_b002
- VirtualWire library changed to the RadioHead library. Install and use only the supplied RadioHead library.
- To prevent some compiler warnings, update the TFT_ILI9341 library with the one included in libraries folder.
Please install the RadioHead library included in the software package.
(20-01-2018, 01:49)Werk_AG Wrote:  Hi Jim,
Sorry for that, copied the supplied library files and it uploaded Tx fine. Now I have issues with the Rx, It complies fine but has issues uploading.
Arduino: 1.8.5 (Windows 10), Board: "Arduino Nano, ATmega328P" C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\JBA\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0X2341_0X0042 -ide-version=10805 -build-path C:\Users\JBA\AppData\Local\Temp\arduino_build_273504 -warnings=none -build-cache C:\Users\JBA\AppData\Local\Temp\arduino_cache_438485 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v5.0\software\TX software\WeatherDuinoPro2_Universal_TX_v5_20012018\WeatherDuinoPro2_Universal_TX_v5_20012018.ino C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\JBA\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0X2341_0X0042 -ide-version=10805 -build-path C:\Users\JBA\AppData\Local\Temp\arduino_build_273504 -warnings=none -build-cache C:\Users\JBA\AppData\Local\Temp\arduino_cache_438485 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\JBA\Documents\Arduino\WeatherDuino_Pro2_PLUS\v5.0\software\TX software\WeatherDuinoPro2_Universal_TX_v5_20012018\WeatherDuinoPro2_Universal_TX_v5_20012018.ino Using board 'nano' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr Using core 'arduino' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr Detecting libraries used... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT1x" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT1x" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT1x" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT1x" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Users\JBA\Documents\Arduino\libraries\DHTxx" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT1x" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Users\JBA\Documents\Arduino\libraries\DHTxx" "-IC:\Users\JBA\Documents\Arduino\libraries\VEML6075" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT1x" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Users\JBA\Documents\Arduino\libraries\DHTxx" "-IC:\Users\JBA\Documents\Arduino\libraries\VEML6075" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT1x" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Users\JBA\Documents\Arduino\libraries\DHTxx" "-IC:\Users\JBA\Documents\Arduino\libraries\VEML6075" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\RunningAverage" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT1x" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Users\JBA\Documents\Arduino\libraries\DHTxx" "-IC:\Users\JBA\Documents\Arduino\libraries\VEML6075" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\RunningAverage" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\EEPROM\src" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT1x" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Users\JBA\Documents\Arduino\libraries\DHTxx" "-IC:\Users\JBA\Documents\Arduino\libraries\VEML6075" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\RunningAverage" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\EEPROM\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "nul" Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHCRC.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHDatagram.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHEncryptedDriver.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHGenericDriver.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHGenericSPI.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHHardwareSPI.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHMesh.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHNRFSPIDriver.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHReliableDatagram.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHRouter.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHSPIDriver.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RHSoftwareSPI.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_ASK.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_CC110.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_E32.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_MRF89.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_NRF24.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_NRF51.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_NRF905.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_RF22.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_RF24.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_RF69.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_RF95.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RadioHead\RH_TCP.cpp Using cached library dependencies for file: C:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp Using cached library dependencies for file: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src\Wire.cpp Using cached library dependencies for file: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\WD_OneWire\WD_OneWire.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature\WD_DallasTemperature.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15\Adafruit_ADS1015.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31\Adafruit_SHT31.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\SHT1x\SHT1x.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\SHT21\SHT2x.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\HTU21D\HTU21D.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\DHTxx\DHTxx.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\VEML6075\VEML6075.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\Timer\Event.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\Timer\Timer.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\RunningAverage\RunningAverage.cpp Using cached library dependencies for file: C:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C\LiquidCrystal_I2C.cpp Generating function prototypes... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT1x" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Users\JBA\Documents\Arduino\libraries\DHTxx" "-IC:\Users\JBA\Documents\Arduino\libraries\VEML6075" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\RunningAverage" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\EEPROM\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\preproc\ctags_target_for_gcc_minus_e.cpp" "C:\Program Files\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\preproc\ctags_target_for_gcc_minus_e.cpp" Compiling sketch... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\JBA\Documents\Arduino\libraries\RadioHead" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_OneWire" "-IC:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15" "-IC:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT1x" "-IC:\Users\JBA\Documents\Arduino\libraries\SHT21" "-IC:\Users\JBA\Documents\Arduino\libraries\HTU21D" "-IC:\Users\JBA\Documents\Arduino\libraries\DHTxx" "-IC:\Users\JBA\Documents\Arduino\libraries\VEML6075" "-IC:\Users\JBA\Documents\Arduino\libraries\Timer" "-IC:\Users\JBA\Documents\Arduino\libraries\RunningAverage" "-IC:\Program Files\Arduino\hardware\arduino\avr\libraries\EEPROM\src" "-IC:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp" -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp.o" Compiling libraries... Compiling library "RadioHead" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHCRC.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHDatagram.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHEncryptedDriver.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHGenericDriver.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHGenericSPI.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHHardwareSPI.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHMesh.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHNRFSPIDriver.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHReliableDatagram.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHRouter.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHSPIDriver.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHSoftwareSPI.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_ASK.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_CC110.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_E32.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_MRF89.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_NRF24.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_NRF51.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_NRF905.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_RF22.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_RF24.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_RF69.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_RF95.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_Serial.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_TCP.cpp.o Compiling library "SPI" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\SPI\SPI.cpp.o Compiling library "Wire" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\Wire\Wire.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\Wire\utility\twi.c.o Compiling library "WD_OneWire" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\WD_OneWire\WD_OneWire.cpp.o Compiling library "WD_DallasTemperature" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\WD_DallasTemperature\WD_DallasTemperature.cpp.o Compiling library "Adafruit_ADS1X15" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\Adafruit_ADS1X15\Adafruit_ADS1015.cpp.o Compiling library "Adafruit_SHT31" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\Adafruit_SHT31\Adafruit_SHT31.cpp.o Compiling library "SHT1x" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\SHT1x\SHT1x.cpp.o Compiling library "SHT21" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\SHT21\SHT2x.cpp.o Compiling library "HTU21D" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\HTU21D\HTU21D.cpp.o Compiling library "DHTxx" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\DHTxx\DHTxx.cpp.o Compiling library "VEML6075" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\VEML6075\VEML6075.cpp.o Compiling library "Timer" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\Timer\Event.cpp.o Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\Timer\Timer.cpp.o Compiling library "RunningAverage" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RunningAverage\RunningAverage.cpp.o Compiling library "EEPROM" Compiling library "LiquidCrystal-I2C" Using previously compiled file: C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\LiquidCrystal-I2C\LiquidCrystal_I2C.cpp.o Compiling core... Using precompiled core Linking everything together... "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504/WeatherDuinoPro2_Universal_TX_v5_20012018.ino.elf" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\sketch\WeatherDuinoPro2_Universal_TX_v5_20012018.ino.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHCRC.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHDatagram.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHEncryptedDriver.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHGenericDriver.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHGenericSPI.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHHardwareSPI.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHMesh.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHNRFSPIDriver.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHReliableDatagram.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHRouter.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHSPIDriver.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RHSoftwareSPI.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_ASK.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_CC110.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_E32.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_MRF89.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_NRF24.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_NRF51.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_NRF905.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_RF22.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_RF24.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_RF69.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_RF95.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_Serial.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RadioHead\RH_TCP.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\SPI\SPI.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\Wire\Wire.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\Wire\utility\twi.c.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\WD_OneWire\WD_OneWire.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\WD_DallasTemperature\WD_DallasTemperature.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\Adafruit_ADS1X15\Adafruit_ADS1015.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\Adafruit_SHT31\Adafruit_SHT31.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\SHT1x\SHT1x.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\SHT21\SHT2x.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\HTU21D\HTU21D.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\DHTxx\DHTxx.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\VEML6075\VEML6075.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\Timer\Event.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\Timer\Timer.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\RunningAverage\RunningAverage.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504\libraries\LiquidCrystal-I2C\LiquidCrystal_I2C.cpp.o" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504/..\arduino_cache_438485\core\core_arduino_avr_nano_cpu_atmega328_5638c217b04eda8279099c4937887265.a" "-LC:\Users\JBA\AppData\Local\Temp\arduino_build_273504" -lm "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504/WeatherDuinoPro2_Universal_TX_v5_20012018.ino.elf" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504/WeatherDuinoPro2_Universal_TX_v5_20012018.ino.eep" "C:\Program Files\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504/WeatherDuinoPro2_Universal_TX_v5_20012018.ino.elf" "C:\Users\JBA\AppData\Local\Temp\arduino_build_273504/WeatherDuinoPro2_Universal_TX_v5_20012018.ino.hex" Multiple libraries were found for "EEPROM.h" Used: C:\Program Files\Arduino\hardware\arduino\avr\libraries\EEPROM Not used: C:\Users\JBA\Documents\Arduino\libraries\EEPROM Using library RadioHead in folder: C:\Users\JBA\Documents\Arduino\libraries\RadioHead (legacy) Using library SPI at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI Using library Wire at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire Using library WD_OneWire in folder: C:\Users\JBA\Documents\Arduino\libraries\WD_OneWire (legacy) Using library WD_DallasTemperature in folder: C:\Users\JBA\Documents\Arduino\libraries\WD_DallasTemperature (legacy) Using library Adafruit_ADS1X15 at version 1.0.0 in folder: C:\Users\JBA\Documents\Arduino\libraries\Adafruit_ADS1X15 Using library Adafruit_SHT31 at version 1.0.0 in folder: C:\Users\JBA\Documents\Arduino\libraries\Adafruit_SHT31 Using library SHT1x in folder: C:\Users\JBA\Documents\Arduino\libraries\SHT1x (legacy) Using library SHT21 in folder: C:\Users\JBA\Documents\Arduino\libraries\SHT21 (legacy) Using library HTU21D in folder: C:\Users\JBA\Documents\Arduino\libraries\HTU21D (legacy) Using library DHTxx in folder: C:\Users\JBA\Documents\Arduino\libraries\DHTxx (legacy) Using library VEML6075 at version 1.0.0 in folder: C:\Users\JBA\Documents\Arduino\libraries\VEML6075 Using library Timer in folder: C:\Users\JBA\Documents\Arduino\libraries\Timer (legacy) Using library RunningAverage in folder: C:\Users\JBA\Documents\Arduino\libraries\RunningAverage (legacy) Using library EEPROM at version 2.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\EEPROM Using library LiquidCrystal-I2C in folder: C:\Users\JBA\Documents\Arduino\libraries\LiquidCrystal-I2C (legacy) Sketch uses 15624 bytes (50%) of program storage space. Maximum is 30720 bytes. Global variables use 1129 bytes (55%) of dynamic memory, leaving 919 bytes for local variables. Maximum is 2048 bytes. C:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM9 -b57600 -D -Uflash:w:C:\Users\JBA\AppData\Local\Temp\arduino_build_273504/WeatherDuinoPro2_Universal_TX_v5_20012018.ino.hex:i avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/         Copyright (c) 2007-2014 Joerg Wunsch         System wide configuration file is "C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf"         Using Port                    : COM9         Using Programmer              : arduino         Overriding Baud Rate          : 57600 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf2 avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x1c avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00 avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x1c avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe0 avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x1c avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x1c avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00 avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe0 avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe0 avrdude done.  Thank you. An error occurred while uploading the sketch
Hi Jim,
You haven't got the Serial monitor open by chance? That looks like the error you see when you do.
Jim, the compiler output on your previous post is from the TX software compilation. Is the upload problem with the TX or with the RX software?
When changing compiling for the Nano to the Mega, check if you don't have to change the com port.
