12-12-2017, 00:27
Hi engolling,
I think it would be interesting for many users of this forum - for example for me
![[Image: 31221858ld.jpg]](http://up.picr.de/31221858ld.jpg)
![[Image: 31221809aj.jpg]](http://up.picr.de/31221809aj.jpg)
![[Image: 31221870cw.jpg]](http://up.picr.de/31221870cw.jpg)
(12-12-2017, 22:17)engolling Wrote: I still have a quotation from the supplier, but I would have to take 100pcs which cost about 20 EUR per Piece including VAT.
So if there is a huge demand we could think of a collective order, but I don't want to have 100 laser ranging devices liying at home.
Since I'm tired in working and debugging alone in my weather station software I'm planning to switch to WeatherDuino and to contribute with some sensor development.
Quote:Unfortunately, Werk_AG is totally busy and will probably be a long time.
(12-12-2017, 22:17)engolling Wrote: Since I'm tired in working and debugging alone in my weather station software I'm planning to switch to WeatherDuino and to contribute with some sensor development.
(13-12-2017, 05:36)Werk_AG Wrote: The problem with any "intregation" is: We can add almost any kind of sensor that we want to the WeatherDuino, but we can't "integrate" everything that we may want in the Davis Emulation. Mapping things to the Davis Extra sensors have huge limitations, and its not a solution for everything, as the data field have only 1 byte (integers values from 0 to 255).
By other words, we can show anything on the screen, but we can't pass anything to a PC or a PI, because to do it we need to follow the Davis Serial protocol, its it that deals with the comunication between the WeatherDuino and the PC or PI (no mather the software we use).
(13-12-2017, 09:45)engolling Wrote: PS. Somewhere is written, that the WeatherDuino supports different 433MHZ rx/tx modules. Is there anywhere a thread where I can see the supported modules? Because I want to set up a decentralized sensor Network and therefore I Need quite some transmission power. Moreover I will start new thread, maybe during the christmas holidays, introducing the sensors I'm using at the moment and my ideas
//Define laser measurement on USART2
#define LASER_POWER_PIN 25
#define LASER_START_PIN 24
#define LASER_HEIGHT 1986
#define LASER_LATENCY 1999 //time for laser to answer in ms
int16_t laser_distance_array[SNOW_ARRAYSIZE] = { -200, -200, -200, -200, -200, -200, -200, -200, -200, -200, -200, -200};
uint8_t laser_distance_array_ind = 0;
uint8_t laser_wd;
uint32_t LaserReqtime;
uint8_t LaserFlag = 0;
union laser_send_data_t {
struct bytes_t {
uint8_t preamble;
uint8_t command;
uint8_t data[3];
uint8_t check_code[2];
} bytes;
uint8_t array[sizeof(bytes)];
} laser_send_data;
union laser_rcv_data_t {
struct bytes_t {
uint8_t preamble;
uint8_t command;
uint8_t result;
uint8_t data[3];
} bytes;
} laser_rcv_data;
pinMode(LASER_POWER_PIN, OUTPUT);
pinMode(LASER_START_PIN, OUTPUT);
digitalWrite(LASER_POWER_PIN, HIGH);
digitalWrite(LASER_START_PIN, HIGH);
delay(50);
digitalWrite(LASER_START_PIN, LOW);
laser_send_data.bytes.preamble = 0xAA;
laser_send_data.bytes.command = 0x03;
Serial2.begin(38400); //Read distance with laser ---- data is retrieved at the end of callback_10s
laser_send_data.bytes.check_code[0] = (uint8_t)(laser_send_data.bytes.preamble + laser_send_data.bytes.command + laser_send_data.bytes.data[0] + laser_send_data.bytes.data[1] + laser_send_data.bytes.data[2]) << 8;
laser_send_data.bytes.check_code[1] = (uint8_t)(laser_send_data.bytes.preamble + laser_send_data.bytes.command + laser_send_data.bytes.data[0] + laser_send_data.bytes.data[1] + laser_send_data.bytes.data[2]);
Watchdog.reset(); //Reset global watchdog, just to make sure that it won't get trapped
Serial2.write(laser_send_data.array, sizeof(laser_send_data.array));
LaserReqtime = millis();
LaserFlag = 1;
//Check laser watchdog reset condition - if watchdog is not resetted within the data retrieving section reboot the laser distance sensor
if (laser_wd < 5) {
laser_wd++;
else {
digitalWrite(LASER_POWER_PIN, LOW);
delay(100);
delay(50);
laser_wd = 0;
//////// Read values of laser distance sensor via USART 2 ///////////////////////
void read_laser(void) {
//Get data of Laser distance measurement
//Try to get data from serial 2
if (Serial2.available() >= 8) {
laser_wd = 0;//Reset Watchdog of laser meter if data is received - device is resettet after 5 sending counts without an answer
//Get data from buffer
Serial2.readBytes(laser_rcv_data.array, sizeof(laser_rcv_data.array));
//Calculate checksum
uint16_t checksum = 0;
for (uint8_t i = 0; i < sizeof(laser_rcv_data.array) - 2; i++) {
checksum = checksum + laser_rcv_data.array[i];
//Calculate distance if command, result and checksum is ok
if ((laser_rcv_data.bytes.command == 0x03) && (laser_rcv_data.bytes.result == 0x06) && (checksum == (laser_rcv_data.bytes.check_code[0] << 8 | laser_rcv_data.bytes.check_code[1]))) {
int32_t distance_temp = ((int32_t)(laser_rcv_data.bytes.data[0] << 16) | (int32_t)(laser_rcv_data.bytes.data[1] << 8) | (int32_t)laser_rcv_data.bytes.data[2]);
if (distance_temp < 32000 && distance_temp > -1) {
laser_distance_array[laser_distance_array_ind] = (int16_t)distance_temp;
//Serial.println(laser_distance_array[laser_distance_array_ind]);
//Move array pointer
if (laser_distance_array_ind < SNOW_ARRAYSIZE) {
laser_distance_array_ind++;
else {
//If laser answers with wrong values
else {
laser_distance_array[laser_distance_array_ind] = -100;
else {
uint32_t uart_timeout = millis();
//Flush serial buffer if something is left for any reason and protect from endless looping
while (Serial2.available() > 0 && (millis() - uart_timeout < 500)) {
Serial2.read();
//Serial.println("Empty Buffer");
