Threads: 27
Weather Station: Alma, MI USA
27-08-2017, 22:00
(This post was last modified: 27-08-2017, 22:02 by
danner.)
Quick question. Is anyone else experiencing occasional wind gust spikes? I might be jumping the gun because I haven't had my FO wind up for that long, but so far I've seen three 25mph wind gust spikes out of nowhere when the other wind gusts are 11mph or so. And if I look on wunderground at stations near me none have any gusts that high.
Again I may be jumping to conclusions as I haven't had the FO wind up for very long, but I thought I would ask if there is something I might have done wrong to cause this? Or is this normal for FO wind gauges and I just need to upgrade them to make it go away?
I'm using CumulusMX running on a RPi3.
TIA
Threads: 27
28-08-2017, 02:29
(This post was last modified: 28-08-2017, 02:30 by
danner.)
OK, thank you.
My ISP messed up my webspace so it is down until they fix it.
tobyportugal
Unregistered
The winds is most difficult to compare with other stations.
I am to 35 km of Werk_AG:
tobyportugal
Unregistered
(28-08-2017, 08:15)uncle_bob Wrote: (28-08-2017, 07:41)tobyportugal Wrote: I am to 35 km of Werk_AG:
Hey, that's real handy for the new product release parties
And Paulo is with… 24 km!!
With Paulo (meteocaldas), we will assemble our WeatherDuino together.
Link Paulo:
http://www.meteocaldas.com/pc/index.php
I apply the currency of Belgium: Unity is strength.
Threads: 337
Little story about why with the WeatherDuino you should use a 0.448 (or even 0.224) multiplier for wind speed and wind gust.
First, take at look at the user configurable settings on the RX software, there is a short explanation there.
Now the story: Davis weather stations measure wind just at 1mph resolution. WeatherDuino can do it a little better, and allows you to chose among three possible resolutions.
When you set this "#define VP2_WindRes" to 2 you get a resolution of 0.72Km/h (0.447mph), if you set that that value to 1, you get an even better resolution of 0.36Km/h(0.223mph), if you set it to 0 you get the standard Davis resolution of 1.62 Km/h (1mph).
So, as we are doing some trick with the Davis protocol, you also need to set on the weather software a multiplier, because it expects to receive values in mph.
This is why if you chose the standard Davis resolution, the multiplier should be 1, otherwise it should be set to the values described in the user configurable settings.
Please also note, that increasing the resolution will also decreases de maximum wind gust possible to be measured. Setting the resolution to 2 is a good compromise for most locations, with that value, the highest wind gust possible to be measured is 183.6 Km/h
Regarding any other adjustment to compensate for the height of the anemometer, I never tried that. In your case the value of 1.12 should be fine if you use the standard Davis resolution. My first impression is that just adding 0.12 to the 0.448 multiplier, will not give correct readings, perhaps something around 0.06 will work, but I'm not sure
Threads: 27
01-09-2017, 22:06
(This post was last modified: 01-09-2017, 22:09 by
danner.)
Thank you for the response. My ambient weather weather station is only 10ft off the ground so I put a 1.25 correction factor on that one to account for its height and wasn't sure where to do that on the WeatherDuino. But I understand now, the .448 is what is set in the Receiver. I'm happy with it's performance now so I'll just leave it alone. It is above my roof line, where the ambient weather is 8ft or so below the roof line, but exposed to the west, which is where the majority of our wind comes from.
I like the way the software averages the direction. That is much better than the other weather stations I've had that only plot the weaving back and forth of the vane.
tobyportugal
Unregistered
Hello Werk/Danner.
If you are a little patient
, I can make a correct comparison of an anemometer Davis on a VP2 and WeatherDuino.
My anemometer is with 8.5m, it is easy to assemble another on a “L”.
I think that it is necessary to be careful with the corrections “software”. 1 + 1 must remain 2 and not 2.1
The same comparison on the UV-W/M2 would be also instructive.
Good weekend
