  • 1 Vote(s) - 3 Average
Soil Moisture and Temperature sensors installation.
Hello Werk,
There are two I2C connectors on this interface: can you use both together to plug up to 8 sensors? Or one is to plug the TX board while the second one can be used as a I2C bus extender?
Thanks,
Olivier
(20-08-2016, 06:42)zitoune Wrote:
(19-06-2016, 16:41)JT118 Wrote:  Here is mine, installed on TX1 (TX0 with rain gauge, anemometer etc)
Very cool JT118 !!
How did you connect the power to this TX1? You have a cable buried in the ground?
I am jealous, so I'll start building my interface as well very soon Smile
Power supply is from mains transformer with cable trailing. (due for burial soon!)
(20-08-2016, 09:17)zitoune Wrote:  Hello Werk,
Thanks,
Olivier
Hi Olivier,
Currently the WeatherDuino Pro2 software only support the use of one Soil Moisture / Leaf Wetness interface.
(21-08-2016, 05:57)Werk_AG Wrote:  Hi Olivier,
Thanks Werk.
Is this interface meant for further use with the Weatherduino 4Pro ?
Regards.
(21-08-2016, 06:00)zitoune Wrote:  Is this interface meant for further use with the Weatherduino 4Pro ?
It is marked as 4Pro! Cool I think just to give it a cool name Smile
Hi Werk_AG,
I have too questions to you, if you can help me (or with the second question another else):
1) this not so important: Is it possible to post the Soil Moisture / Leaf Wetness Interface schema?
2) this more important for me: when I study P82B715 datasheet to manage the Rx values, I found Fig. 9 in the chapter 8.2 = Quick design-in point-to-point/multi-point information for 5 V bus. They recommend to put resistance 4.7kOhm on each I2C-bus (SDA and SCL) and on each end of the cable resistance 470Ohm (buffered bus, LSDA, LSCL). It would be satisfactory up to long 30 or maybe 50m of UTP cable Cat5e. Do you agree, please, with this idea?
[Image: P82B715_P2P_P2M.JPG]
My installation will have 8 m of outdoor UTP Cat5e cable ...
(19-09-2016, 15:59)hornychz Wrote:  1) this not so important: Is it possible to post the Soil Moisture / Leaf Wetness Interface schema?
This is here hornychz Wink
(19-09-2016, 16:50)zitoune Wrote:  This is here hornychz Wink
I obviously totally blind ... Wink
Thank you!
... and maybe it is all at once the answer to my second question ... ?? Idea
Werk mentions that calculating the correct values of those 2 resistors and the 2 on the TX is important for long wires indeed Smile
Users browsing this thread: 19 Guest(s)
