Use auriol compatible sensors with weatherduino
Quote:Today I tried to measure the voltage produced by my photodiode with a 235 ohm R in parallel. I recorded a maximum of 330 mV (weather stations near me have recorded about 660 w / m 2). I believe that by calibrating a little the resistance we can get a 1.1 volt (considering that from me 1300 w / m2 have a limit more than ample))
Just be aware of this:
"There is a trade-off between the desire to increase the output voltage (by increasing the resistance) and the need to make sure that the pyranometer output remains linearly proportional to the incident sunlight. "
This is from the link you published. It's valid for my solar sensor and probably for any other that use the same principle.
With some calcolation I think 47 ohm is a good solution to use your same amplification solution.
I started to build the X. A couple of questions. The variable resistor is used just 15k? If I do not use the fan can live without it? To test it out I can connect the TX only with usb? Thanks.
Loris
(10-10-2014, 18:22)loriz71 Wrote:  ... A couple of questions. The variable resistor is used just 15k?
On the TX board, the R8 variable resistor must be adjusted to 10K as close as you can.
Quote:If I do not use the fan can live without it?
The fan is not required. You may build your Radition Shield without it.
Quote: To test it out I can connect the TX only with usb?
For testing, yes you can!
On the TX software, find this line: //#define Local_TestMode
and uncomment it.
Compile and upload.
Open Arduino IDE serial monitor. Almost every 3 seconds you will see a line of data. This data follow the easyweather.dat format.
There is an easier way to view the data sent by the USB port:
Install the Easyweather_RS232_Logger (freeware)
Download it from here: http://www.meteoestarreja.info/logger.php/
Hello
I have some doubts.
I have indicated in Annex positions of the cathodes of the LEDs and diode. Are they correct?
I have some difficulty in finding a variable resistance 15 k ohm (I find 10 k). what is the function of R8? I hope that by next week all the components to test the TX arrives
B.R.
loris
Hi Loris
The Led's and the diode are correct. At first look they seems reversed but they are not. The MosFET's drives the GND line.
The diode is only a protection just in case someone use the fan as a wind mill. SmileSmile
Any variable resistor greater than 10K will be fine for R8. Even a fixed 10K 1% resistor will do the job, but you loose the possibility to fine adjust your wind vane. Usually this procedure is not necessary, the variable resistor is there, just in case...
