10-02-2016, 00:16
I'm gonna describe a small trick that will decrease the power consumption of a TX board, avoiding the power loss in the 7809 linear voltage regulator... additionally with care, you can also increase radio signal range.
This trick will cost less than $1.
- If you have the 7809 already installed, remove it.
- On the TX board, do a shunt between input and output pins of the 7809 regulator.
- Buy on eBay or wherever you which a step down converter module like this ine below. They cost less than $1
![[Image: m6K-zF7pP4CF4DmAKCFp5Ig.jpg]](http://thumbs4.ebaystatic.com/d/l225/m/m6K-zF7pP4CF4DmAKCFp5Ig.jpg)
- Connect your power source to the module input, and adjust voltage output to 9V.
- Connect the output of the module, to TX power in.
- If you are using +Bat pin to monitor the battery voltage in a solar system, just keep it connected to positive (+) battery terminal.
How just doing this will increase my radio signal range? Just doing this don't do it!
But... if you carefully adjust the voltage output of the step down converter to up to 10V, the radio signal range will be slightly improved.
Vendors claim that the RF power transistor can be powered up to 12V. According to my experience with the RF modules used in the WeatherDuino TX, don't go further than 10V.
And that's all. Less power consumption and a few more meters in RF signal range.
