Hi uncle_bob
Yeah, we are thinking the same thing. A possible problem in the connection between the Dat pin and D9.
Sometime I had a similar problem with a socket. Everything was well when checking at the socket pins at the board, but when I put the Nano on the socket, one of the pins have no contact.
Threads: 31
Weather Station: Conder Weather, Canberra
Werk_AG, are there any pass though holes, can't remember correct term at the moment (via maybe?), from one side to the other side of the PCB? If so, maybe it hasn't been filled with solder at the factory?
Yes, there are two in that line.
A problem with the vias can also be a possibility, despite until now I haven't any report about a similar problem. The next step after a simple continuity test between Dat and D9 pin, will be testing any of the two pass-through vias on the board.
