Weatherduino troubleshooting
If you get real stuck you can sent it to me and I'll take a look at it Pete.
(05-01-2023, 08:22)uncle_bob Wrote:  If you get real stuck you can sent it to me and I'll take a look at it Pete.
Thanks Bob I might end up taking you up on a very generous offer- but i will persevere a little longer for now.
(02-01-2023, 19:55)hornychz Wrote:
(02-01-2023, 06:56)coupe pete Wrote:  I then disconnected the power and removed the Nano and inspected it. Could not see any issues. I then reconnected it and disconnected it about 5 times and it did not make any difference.  When I pressed the reset button on the nano the "l" LED next to the power LED on the nano flashed briefly.
I then reflashed the nano and it did not seem to make any difference.
I then replaced it with a new nano and that did not seem to make a difference.
I then checked the voltages on the TX board. The 3.3, 5 and 9V connection points all had the correct voltage. The Battery voltage was 14.4 volts, it was a bright sunny day.
I placed the multimeter on the TX LED and the voltage was pulsing even though i could not see the LED flashing. Not sure if the LED is working ? or if its just nor visible in bright daylight
None of this seemed to help as the receiver is still not getting any data.
Open to suggestions on where to go next ?
I would definitely try the debug mode. This means enabling the debug outputs of the TX unit to the USB port, upload new firmware and watching the output in Arduino IDE monitor...
// -------------------------------------------------------------------------------------- // Debug // -------------------------------------------------------------------------------------- #define ENABLE_DEBUG #define DEBUG_ID0 #define DEBUG_ID2 #define DEBUG_ID3 #define DEBUG_ID4 #define DEBUG_ID5 //#define DEBUG_SLINTERFACE //#define EASYWEATHER_TEST
If you didn't know what the identifiers 0 to 5 mean, their description is in the Config_Options.h file just a little higher:
// -------------------------------------------------------------------------------------- // Define which data this unit will send. 0 = Not send this data, 1= Send this data // -------------------------------------------------------------------------------------- #define ID0 1 // Temp/Hum Data #define ID1 0 // Not Used #define ID2 1 // Wind data #define ID3 1 // Rain data #define ID4 0 // SolRad / UV data #define ID5 1 // Hardware Status - System Temp, Battery Voltage etc
And after doing it put the output here, please.
(It is also possible that after a few years of "being outside" the entire PCB will need to be resoldered. It depends on how well prepared it was for the outdoor environment.)
OK. Had a go at this tonight. This is how I configured the debug terms..
#define ENABLE_DEBUG      true
#define DEBUG_ID0         true
#define DEBUG_ID2         true
#define DEBUG_ID3         true
#define DEBUG_ID4         false
#define DEBUG_ID5         true
#define DEBUG_SLINTERFACE true
#define EASYWEATHER_TEST  true
Port was com4. Baud rate was set to 9600 and "no line ending" was chosen.
This was the output - which I assume is rubbish. Is there anything i did wrong ?
0, 0, 0, 0, 15, 0, 50, 20.0, 0,ߝ⸮⸮M)9⸮⸮þk⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮ ⸮⸮S@O⸮ ⸮⸮⸮gg⸮H⸮⸮⸮ggSJ'⸮H    *H    *x    ⸮x*H**H    **H    *H    A⸮ ⸮ ⸮⸮ ⸮⸮ ⸮ ⸮ ⸮ ⸮⸮⸮ ⸮⸮⸮M)9⸮⸮þk⸮ ⸮⸮⸮⸮⸮B⸮⸮⸮⸮⸮⸮⸮⸮N⸮⸮H⸮⸮⸮S@O⸮ ⸮⸮⸮ggS⸮⸮⸮⸮ggSJ⸮⸮ ⸮⸮⸮M)9⸮Vþk⸮ ⸮⸮⸮⸮⸮~⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S@O⸮ ⸮⸮⸮ggS⸮⸮⸮⸮'gSJ⸮⸮H    *H    *X*H    ⸮HȨ Ȉ ⸮ ⸮.⸮ ⸮ ⸮ @K⸮ ⸮⸮ ⸮ ⸮⸮⸮⸮⸮⸮⸮M)9⸮⸮þk⸮0 ⸮⸮⸮⸮⸮⸮⸮⸮⸮1⸮⸮⸮⸮NX⸮H⸮⸮⸮S@O⸮ ⸮⸮⸮gg3⸮⸮⸮⸮ggSJ$⸮H    *H    *X ⸮⸮HȈ Ȉ ⸮ ⸮⸮ ⸮ ⸮ @K⸮ ⸮⸮ ⸮ ⸮⸮⸮ ⸮⸮⸮M)9⸮⸮þk⸮ Ș⸮⸮⸮⸮⸮⸮⸮⸮.⸮⸮⸮⸮NX⸮H⸮⸮⸮9@O⸮ ⸮⸮⸮ggS⸮⸮⸮⸮ggSJ⸮⸮ ⸮⸮⸮M)E⸮⸮ o JI ʈ⸮ 9!⸮o *J⸮ *J ⸮ ⸮⸮⸮⸮)9⸮⸮þk⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S@O⸮ ⸮⸮⸮ggS⸮⸮⸮⸮ggSJ⸮⸮H    *H    ⸮H*H    ⸮HȈH⸮HȈ,⸮ ⸮⸮ ⸮ ⸮ @K⸮ ⸮⸮ ⸮ ⸮⸮⸮ ⸮⸮⸮M)G⸮⸮þk⸮ ⸮⸮⸮$⸮⸮⸮⸮⸮⸮⸮8⸮⸮NX⸮H⸮⸮⸮S@O⸮ ⸮⸮⸮ggS⸮⸮⸮⸮⸮ggSJ⸮⸮؝⸮⸮M)9⸮⸮þk⸮1 ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮k⸮⸮S@O⸮ ⸮⸮⸮gg9⸮⸮⸮⸮ggSJ$⸮H    *⸮    *H ⸮⸮HȈH⸮HȨ ⸮ ⸮⸮ ⸮ ⸮ @K⸮ ⸮⸮ ⸮ ⸮⸮⸮ ⸮⸮⸮⸮)9⸮⸮þk⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S`O⸮ ⸮⸮⸮ggS⸮t⸮⸮⸮ggSJ⸮⸮H    *H    *X*H    ⸮HȈH⸮HȈ ⸮ ⸮⸮ ⸮ ⸮ @K⸮ ⸮⸮ ⸮ ⸮⸮⸮ ⸮⸮⸮M)9⸮⸮þk⸮ ⸮⸮⸮⸮⸮(⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S@Ot ⸮⸮⸮ggS⸮⸮⸮⸮ggSJ⸮⸮ߝ⸮⸮])9⸮⸮gߎ *z ⸮ ⸮⸮H⸮ ⸮⸮Ψ⸮⸮⸮!⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮⸮M⸮9⸮⸮þk⸮ ⸮⸮⸮r⸮⸮⸮⸮⸮⸮⸮$⸮⸮NX⸮H⸮⸮⸮S@⸮ ⸮⸮⸮ggS⸮⸮⸮⸮⸮ggSJ⸮⸮ ⸮⸮⸮M)9⸮⸮ o JI D ⸮ ⸮ 9!⸮o⸮*J⸮ *J ⸮H    *H    *X ⸮⸮HȈH⸮HȈ ⸮ ⸮⸮ ⸮%⸮ @K⸮ ⸮⸮ ⸮ N⸮⸮⸮⸮⸮⸮M)9⸮⸮þk⸮0 ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S@O⸮ ⸮⸮⸮gg9⸮⸮⸮⸮ggSJ$⸮ Ž⸮M)9⸮⸮þk⸮ d⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮NX⸮H⸮⸮.⸮S@O⸮ ⸮⸮⸮ggS(⸮⸮⸮⸮ggSJ⸮⸮H    *H    *h⸮H    ⸮HȈH⸮HȈ ⸮! ⸮⸮ ⸮ ⸮ @K⸮ ⸮⸮ ⸮% N⸮⸮ ⸮⸮⸮M)9⸮⸮þk⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S@O⸮ ⸮⸮⸮ggS⸮⸮⸮⸮ggSj⸮⸮H    *H    *h ⸮⸮HȈH⸮HȈ ⸮ ⸮%⸮ ⸮ ⸮ @K⸮ ⸮⸮ ⸮ N⸮⸮ ⸮⸮⸮M)9⸮⸮þk⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NX⸮Hv⸮⸮S@O⸮ ⸮⸮⸮g1S⸮⸮⸮⸮ggSJ⸮⸮ ⸮⸮⸮M)9⸮⸮⸮þk⸮ ⸮⸮⸮⸮⸮)⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S@Ov ⸮⸮⸮ggS⸮⸮⸮⸮ggSJ⸮⸮H    *H    *x⸮H    ⸮HȈH⸮HȈ ⸮ ⸮⸮ ⸮ ⸮ @K⸮ ⸮⸮ ⸮$ N⸮⸮ ⸮⸮⸮⸮)9⸮⸮ o JI⸮⸮ ⸮ ⸮ 9!⸮o⸮ *J ⸮ ݽ⸮M)9⸮⸮þk⸮ l⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮NX⸮H⸮⸮⸮S@O⸮ ⸮⸮⸮ggS(⸮⸮⸮⸮ggSJ⸮⸮H    *H    *x ⸮⸮HȈH⸮HȈ ⸮ ⸮⸮ ⸮ ⸮ @K⸮ ⸮⸮ ⸮ N⸮⸮ ⸮⸮⸮M)9⸮⸮þk⸮ ⸮⸮⸮d⸮⸮⸮⸮⸮⸮⸮(⸮⸮NX⸮H⸮⸮⸮S@⸮ ⸮⸮⸮ggS⸮⸮⸮⸮⸮ggSJ⸮⸮ ⸮⸮⸮M)9⸮⸮þk⸮ 蘿⸮⸮⸮⸮⸮⸮⸮$⸮⸮⸮⸮NX⸮H⸮⸮^S@O⸮ ⸮⸮⸮ggS⸮⸮⸮⸮ggSJ⸮⸮H    *H⸮*h*H    ⸮HȈH⸮HȈ ⸮ ⸮⸮ ⸮( ⸮ @K⸮ ⸮⸮$⸮ N⸮⸮ ⸮⸮⸮M)9⸮⸮þk⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NX⸮Hr⸮⸮S@O⸮ ⸮⸮⸮ggS⸮⸮⸮⸮ggS(J⸮⸮ ⸮⸮⸮])9⸮⸮g߾⸮*z ⸮ ⸮⸮H⸮ ⸮⸮⸮Ψ⸮⸮⸮!⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮⸮M)9⸮⸮þ#⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NX⸮⸮⸮⸮⸮S@O⸮ ⸮⸮⸮!gS⸮⸮⸮⸮ggJ⸮⸮H    *⸮    *h ⸮⸮HȈH⸮HȈ ⸮ ⸮⸮ ⸮ ⸮ @K⸮ ⸮⸮( ⸮ N⸮⸮ ⸮⸮⸮M)9$⸮þk⸮ ⸮⸮⸮⸮⸮(⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S@Ot ⸮⸮⸮ggS⸮⸮⸮⸮ggSJ⸮⸮ ⸮⸮⸮M)9⸮99!⸮o JI⸮ ⸮⸮⸮ 9!⸮o *J⸮ *J ⸮H    *H    *x*H    ⸮!ȈH⸮HȈ ⸮ &⸮⸮ ⸮ ⸮ @K⸮ ⸮⸮ ⸮ N⸮⸮ ⸮⸮⸮M)9⸮⸮þ!⸮ ⸮⸮⸮⸮⸮⸮⸮⸮!⸮⸮⸮⸮⸮⸮NX⸮⸮⸮⸮⸮S@O⸮ ⸮⸮⸮BgS⸮⸮⸮⸮ggJ⸮⸮ ⸮⸮⸮M)9⸮⸮⸮ oØ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S@O⸮ ⸮⸮⸮ggS⸮⸮⸮⸮g7SJ⸮⸮H    *H    *x ⸮⸮HȈH⸮HȈ ⸮$⸮⸮ ⸮ ⸮,@K⸮ ⸮⸮ ⸮ ⸮N⸮⸮ ⸮⸮⸮M⸮9⸮⸮þk⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S@O⸮ ⸮⸮⸮ggS⸮D⸮⸮⸮ggSJ⸮⸮ ⸮⸮⸮})9⸮⸮ j H⸮⸮HX*⸮ `⸮o⸮ H H⸮o h⸮ ⸮ ⸮⸮⸮M)9⸮⸮þk⸮ ⸮⸮⸮⸮⸮⸮⸮#!⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S@O⸮ ⸮⸮(ggS⸮⸮⸮⸮ggSJ⸮⸮H    *H    *H*H    ⸮HȈ⸮HȈ ⸮ ⸮&⸮ ⸮ ⸮ @K⸮ ⸮⸮ ⸮ N⸮⸮ ⸮⸮⸮M)9⸮⸮Äk⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NXUH⸮⸮⸮S@O⸮ ⸮⸮⸮ggS⸮⸮⸮⸮ggSJ⸮⸮ ⸮⸮M)9⸮⸮ o ⸮  ⸮⸮ 9!⸮? *J⸮ *J ⸮⸮⸮⸮⸮M)9⸮⸮þk⸮0 ⸮⸮⸮⸮⸮⸮⸮⸮⸮b⸮⸮⸮⸮NX⸮H⸮k⸮⸮S@O⸮ ⸮⸮⸮gg9⸮⸮⸮⸮ggSJ& ⸮ ⸮ L ⸮⸮HȈH⸮HȈ ⸮ ⸮ ⸮ ⸮ ⸮ @K⸮ ⸮⸮ ⸮ N⸮⸮ ⸮⸮⸮⸮)9⸮⸮þk⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S@O⸮ ⸮⸮⸮ggS⸮t⸮⸮⸮ggSJ⸮⸮H    *H    *X⸮⸮⸮H⸮⸮H⸮HȈ ⸮ ⸮⸮ ⸮ ⸮ @K⸮( ⸮⸮ ⸮ N⸮D ⸮⸮⸮M)9⸮⸮Îk⸮ ⸮⸮⸮⸮⸮⸮⸮ !⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S@O⸮ ⸮⸮$ggS⸮⸮⸮⸮gg⸮XJ⸮⸮ ⸮⸮⸮])9⸮⸮'߾ *z ⸮ ⸮⸮H⸮ ⸮⸮Ψ⸮⸮⸮!⸮(⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮M)9⸮⸮þk⸮0 ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮NX⸮H⸮⸮⸮S@O⸮ ⸮⸮⸮gg9⸮⸮⸮⸮ggSJ&⸮H    *H    *X+H    ⸮H⸮⸮H⸮HȈ ⸮ ⸮⸮ ⸮ ⸮ @K⸮( ⸮⸮ ⸮ N⸮ ⸮⸮⸮M)9⸮⸮⸮þk⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮v⸮NX⸮H⸮⸮⸮S@O@⸮ ⸮⸮⸮ggS⸮⸮⸮⸮ggSJ⸮⸮ ⸮⸮⸮M)9⸮⸮þk⸮ ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮(⸮⸮⸮⸮NX⸮H⸮⸮bS@O⸮ ⸮⸮⸮ggS(⸮⸮⸮⸮ggSJ⸮D⸮ ⸮ ⸮  ,J  ⸮ ⸮⸮ ⸮ ⸮⸮ ⸮
You have to set the baud rate to 19200...
And bring the output inside code tags, please.
Thanks for the advice here is the output. Sorry but I dont understand "bring the output inside the code tags".  I did notice there is some minor "schmutz" on the RF TX board. I cleaned this up but it does not seem to have made a difference. The TX LED on the nano now flashes regularly, but not the tx led on the tx board. I assume the device should still "work" with the IDE monitor configured "on" ?
EDIT by hornychz:
Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 109.04   WindDir: 245  WindDirName: SW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 5, 0, 50, 20.0, 0, 0.0, 0, 0, 0, 1000.00, 0.00, 0, 30.29, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 0.00, Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 5.80   WindDir: 245  WindDirName: SW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 4.85   WindDir: 245  WindDirName: SW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 10, 0, 50, 20.0, 0, 0.0, 0, 0, 0, 1000.00, 0.00, 0, 1.35, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 0.00, Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 5.04   WindDir: 245  WindDirName: SW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 15, 0, 50, 20.0, 0, 0.0, 0, 0, 0, 1000.00, 0.00, 0, 1.40, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 0.00, Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 3.77   WindDir: 245  WindDirName: SW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID0...   Sensor 0 - Temp: 15.40  Hum: 98.15   Sensor 1 - Temp: 0.00  Hum: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 2.43   WindDir: 245  WindDirName: SW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 20, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 0.67, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 0.00, Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 2.22   WindDir: 245  WindDirName: SW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 4.03   WindDir: 245  WindDirName: SW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 25, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 1.12, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 0.00, Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 4.11   WindDir: 245  WindDirName: SW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 30, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 1.14, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 0.00, Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 5.54   WindDir: 245  WindDirName: SW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID3...   Collector Type: 0.25   Total Rain: 2555.748   Rain Fall Tips /h: 0   Rain Fall Rate mm/h: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 6.30   WindDir: 245  WindDirName: SW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID0...   Sensor 0 - Temp: 15.42  Hum: 98.11   Sensor 1 - Temp: 0.00  Hum: 0.00    0, 0, 0, 0, 35, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 1.75, 0, 0, SW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 7.86   WindDir: 249  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 8.19   WindDir: 250  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 40, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 2.28, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 5.80   WindDir: 250  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 45, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 1.61, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 5.90   WindDir: 250  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 7.67   WindDir: 250  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 50, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 2.13, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID0...   Sensor 0 - Temp: 15.44  Hum: 98.19   Sensor 1 - Temp: 0.00  Hum: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 8.66   WindDir: 250  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 55, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 0.00, 0, 2.41, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 8.72   WindDir: 253  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 0.00  WindGust Km/h: 8.12   WindDir: 254  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 60, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 1.46, 0, 2.26, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 5.92   WindDir: 254  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID3...   Collector Type: 0.25   Total Rain: 2555.748   Rain Fall Tips /h: 0   Rain Fall Rate mm/h: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 7.22   WindDir: 255  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 65, 0, 50, 20.0, 98, 15.4, 0, 0, 0, 1000.00, 1.46, 0, 2.01, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 7.44   WindDir: 259  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID0...   Sensor 0 - Temp: 15.45  Hum: 98.14   Sensor 1 - Temp: 0.00  Hum: 0.00    0, 0, 0, 0, 70, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 2.07, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 9.19   WindDir: 262  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 9.38   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 75, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 2.61, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 8.09   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID5...   A2 :684  BatVolt : 13.51   SysTempADC : 1023  SysTempC :59.89  Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 5.83   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 80, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 1.62, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 6.51   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID0...   Sensor 0 - Temp: 15.45  Hum: 98.14   Sensor 1 - Temp: 0.00  Hum: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 7.88   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 86, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 2.19, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 7.87   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 91, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 2.19, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 7.80   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID3...   Collector Type: 0.25   Total Rain: 2555.748   Rain Fall Tips /h: 0   Rain Fall Rate mm/h: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 6.74   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 96, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 1.87, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 5.77   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 5.68   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 101, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 1.58, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID0...   Sensor 0 - Temp: 15.45  Hum: 98.14   Sensor 1 - Temp: 0.00  Hum: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 5.62   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 106, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 1.56, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 6.74   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 7.03   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 111, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 1.95, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 5.45   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 3.75   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 116, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.46, 0, 1.04, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID0...   Sensor 0 - Temp: 15.45  Hum: 98.13   Sensor 1 - Temp: 0.00  Hum: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 5.25  WindGust Km/h: 2.71   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 121, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.75, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 2.58   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID3...   Collector Type: 0.25   Total Rain: 2555.748   Rain Fall Tips /h: 0   Rain Fall Rate mm/h: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 3.27   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 126, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.91, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 3.40   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 131, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.95, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 2.19   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 2.50   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID0...   Sensor 0 - Temp: 15.46  Hum: 98.07   Sensor 1 - Temp: 0.00  Hum: 0.00    0, 0, 0, 0, 137, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.69, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 1.58   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 5.04   WindDir: 265  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 142, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 1.40, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 7.17   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 147, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 1.99, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 6.93   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 4.67   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 152, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 1.30, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID0...   Sensor 0 - Temp: 15.45  Hum: 98.06   Sensor 1 - Temp: 0.00  Hum: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 4.28   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID3...   Collector Type: 0.25   Total Rain: 2555.748   Rain Fall Tips /h: 0   Rain Fall Rate mm/h: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 3.87   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 157, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 1.08, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID5...   A2 :685  BatVolt : 13.53   SysTempADC : 1023  SysTempC :59.89  Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 2.51   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 162, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.70, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 3.29   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 4.83   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 167, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 1.34, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 4.41   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID0...   Sensor 0 - Temp: 15.46  Hum: 98.07   Sensor 1 - Temp: 0.00  Hum: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 3.37   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 172, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.94, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 2.35   WindDir: 264  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 177, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.57, 0, 0.65, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.64  WindGust Km/h: 6.11   WindDir: 263  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 5.03  WindGust Km/h: 9.98   WindDir: 262  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 182, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 2.77, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.03  WindGust Km/h: 11.20   WindDir: 247  WindDirName: SW   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID3...   Collector Type: 0.25   Total Rain: 2555.748   Rain Fall Tips /h: 0   Rain Fall Rate mm/h: 0.00   Sending ID0...   Sensor 0 - Temp: 15.51  Hum: 98.09   Sensor 1 - Temp: 0.00  Hum: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 5.03  WindGust Km/h: 8.92   WindDir: 253  WindDirName: WSW   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 188, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 2.48, 0, 0, WSW, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.03  WindGust Km/h: 11.55   WindDir: 274  WindDirName: W   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 193, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 3.21, 0, 0, W, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.03  WindGust Km/h: 11.40   WindDir: 274  WindDirName: W   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 5.03  WindGust Km/h: 8.79   WindDir: 274  WindDirName: W   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 198, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 2.44, 0, 0, W, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.03  WindGust Km/h: 7.17   WindDir: 274  WindDirName: W   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 5.03  WindGust Km/h: 5.85   WindDir: 274  WindDirName: W   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 203, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 1.62, 0, 0, W, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID0...   Sensor 0 - Temp: 15.51  Hum: 98.14   Sensor 1 - Temp: 0.00  Hum: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 5.03  WindGust Km/h: 2.99   WindDir: 274  WindDirName: W   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 208, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 0.83, 0, 0, W, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.03  WindGust Km/h: 7.04   WindDir: 273  WindDirName: W   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID2...   Wind Speed Km/h (10m Avg): 5.03  WindGust Km/h: 5.62   WindDir: 273  WindDirName: W   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 213, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 1.56, 0, 0, W, 0, 0, 0, 0.00, 0, 0, 0, 2555.75, Sending ID2...   Wind Speed Km/h (10m Avg): 5.03  WindGust Km/h: 4.91   WindDir: 273  WindDirName: W   Min Vane Reading: 0  -  Max Vane Reading: 1023 Sending ID3...   Collector Type: 0.25   Total Rain: 2555.748   Rain Fall Tips /h: 0   Rain Fall Rate mm/h: 0.00   Sending ID2...   Wind Speed Km/h (10m Avg): 5.03  WindGust Km/h: 3.80   WindDir: 273  WindDirName: W   Min Vane Reading: 0  -  Max Vane Reading: 1023  0, 0, 0, 0, 218, 0, 50, 20.0, 98, 15.5, 0, 0, 0, 1000.00, 1.40, 0, 1.05, 0, 0, W, 0, 0, 0, 0.00, 0, 0, 0, 2555.75,
(11-01-2023, 23:29)coupe pete Wrote:  Correct debug:
Not correct:
#define ENABLE_DEBUG      true #define DEBUG_ID0         true #define DEBUG_ID2         true #define DEBUG_ID3         true #define DEBUG_ID4         false #define DEBUG_ID5         true #define DEBUG_SLINTERFACE true #define EASYWEATHER_TEST  true
You don't need to write "true" for debug definitions... You only need remove "//" at the beginning of the lines. But I think the output will be the same.
In my opinion, you have almost the whole board in order, it receives, processes and sends data correctly. It is possible that the transmitter module
is not working, I would recommend replacing it.
I didn't notice which TX unit you are using, what version it is. Tell us, please. And can you post a photo of the transmitter module?
(The transmitter module should probably always have the transmitter antenna connected, it should not be running "idle".)
Yes, now I can see it - you have TX v3.12...
It means you have:
KXD-10036 RF Transmitter Module 433MHZ
Please, change it.
Picture attached.  I disconnect power before disconnecting anything on the board.
Just wondering how to find the correct TX module.
The parts list i found says it should be a  KXD-10036 RF Transmitter Module 433MHZ which is what i currently have and seems impossible to find.
I found a thread by Werk which references a different type of part ? link shown below :-
433Mhz Wireless Transmitter ASK DC 3-12V Perfect for Arduino/ARM/AVR | eBay
Is either fine or do i need an exact replacement for what I have ?
