13-03-2022, 20:31
To cover the sensors, I will suggest the use Quartz Fused Silica Glass. Its not a cheap material but a small piece isn't too expensive.
Among the easily available materials I thing it have the best UV transmission, and doesn't cut much light which is very important for both sensors to work properly with the hardware and software.
PTFE will cut too much light, don't use it on top of the mini solar panel.
Product:UV Grade Fused Silica Quartz Glass
Type:JGS1
Diameter:75mm
Thickness:2.0mm
![[Image: HTB1ASzNB2uSBuNkHFqDq6xfhVXau.jpg]](https://ae01.alicdn.com/kf/HTB1ASzNB2uSBuNkHFqDq6xfhVXau.jpg)
That is an important point. When comparing with a Davis or Apogee instruments (I have two Apogee SP-110) the results are quite similar, by a fraction of the price.
WeatherDuino also supports the VEML6075. Indeed, as AllyCat said, currently it is quite expensive (around 20€ at AliExpress), but seems a good UVB sensor (it provides readings of both UVA and UVB, then some math on the library returns the UV Index).
As a side note, the reason why the 4Pro TX have two extended I2C ports, is to use one for the T/H sensor, and the other for another I2C sensor, like the VEML6075 (normally both aren't placed on the same place, which will require two independent cables).
Of course the second half of the extended I2C circuit (two pcb's are supplied) must be on the side of the sensors.
Type:JGS1
Diameter:75mm
Thickness:2.0mm
Quote:I am quite happy with that. The met office said a high of 1 for UV.
I will keep monitoring the results but seeing that the solar panel cost about £5 and the UV sensor was also about £5 I am not expecting super accuracy.
(13-03-2022, 13:01)AllyCat Wrote: ...
or a true UVB sensor such as the VEML6075 (which has sadly got quite expensive now).
Congratulations!
