I don't know if y'all know of this amazing stuff... I used it almost 35 years now, and have it always in stock
It's a compound which will get very sticky when you knead it a bit and when applied it adheres very good on every clean material.
It will keep connections sealed/watertight for many(!) years!
The synthetic oil in the compound will keep it flexible and when removed and kneaded, it will perform it's protective function very well again.
I use is for protection of for example the antenna connections, keeping nuts and bolt from rusting, cover openings in cases etc etc
It is very easy to remove and use again...
it's called Duxseal
it's called Duxseal
