Wunderground upload OK but 'dot' remains red
After almost 2 years I updated all the software of my WeatherDuino system...
But now I notice that the middle 'dot' remains red although Wunderground did receive data correctly.
I think the problem is with the unexpected response?
Maybe there is just a very simple solution for this?
Wink
I have this software version for my Pro2 receiver:
P2AT2560_RX_v9.0_b004
This is the related message:
Quote:Uploading to Wunderground
Create tcp OK
Waiting for WU response...
WU connection failed!
This is the serial data after reset, just FYI:
ESP8266 FW Version: WIFI GOT IP AT+GMR AT version:1.3.0.0(Jul 14 2016 18:54:01) SDK version:2.0.0(5a875ba) v1.0.0.3 Mar 13 2018 09:37:06 OK Mode station OK Multiple mux OK Join AP success! Connected to AP: AT+CWJAP? +CWJAP:"xxxxxxxxxxxxx","xx.xx.xx.xx.xx.xx",6,-59 OK IP Address: xxx.xxx.xxx.xx Broadcast IP: xxx.xxx.xxx.xxx RTC current date & time: 23 Jun 2021 14:37 Sending NTP request to sync clock... NTP replied   UTC date & time from NTP server: 23 Jun 2021 12:37 RTC adjusted to local date & time: 23 Jun 2021 14:37           Reading RTC date & time: 23 Jun 2021 14:37 System current date: 23/06/2021 System current time: 14:37:49 Checking for latest software version... Latest software version: P2AT2560_RX_v9.0_b004 WiFi connection is ON 14:38:04 - Station ID: A1  Unit ID: 0  Sensor ID: 0  Full Message: A10000,7D4,17DE,0,0, 14:38:05 - Station ID: A1  Unit ID: 1  Sensor ID: 2  Full Message: A10012,83C,D46,172,A1D, 14:38:08 - Station ID: A1  Unit ID: 1  Sensor ID: 2  Full Message: A10012,83C,E81,15E,A1D, 14:38:10 - Station ID: A1  Unit ID: 2  Sensor ID: 3  Full Message: A10023,FE,0,1D,0, SystemInit2 DONE! Connected to: xxx.xxx.xxx.xx 14:38:12 - Station ID: A1  Unit ID: 1  Sensor ID: 2  Full Message: A10012,87B,BB8,15E,AC5, 14:38:14 - Station ID: A1  Unit ID: 1  Sensor ID: 2  Full Message: A10012,87B,815,15E,AC5, 14:38:17 - Station ID: A1  Unit ID: 1  Sensor ID: 2  Full Message: A10012,87B,559,15E,AC5, 14:38:20 - Station ID: A1  Unit ID: 1  Sensor ID: 2  Full Message: A10012,87B,65A,172,AC5,
(23-06-2021, 13:44)edr1924 Wrote:  After almost 2 years I updated all the software of my WeatherDuino system...
Wink
I think this could happen, whenever the WU server take more than 2s to reply. When this happen, the Pro2 PLUS goes on, without waiting for the answer and the upload is signalized as failed, but, as you said, the data upload was done.
We can increase the waiting for answer timeout,  but that will have impact on the capability of receiving data (while it is waiting, there is no reception of RF data).
Is good to know that your system is being work for two years.
Wink
Ok, thank you for your reply, will make the dot green myself Wink
