Threads: 336
Despite the value shown on the schematic, all Pro2 PLUS boards were and are supplied with an 4 Ohms resistor at R1. Value is not very critical, it could be 4.3 Ohms, but not too high, or it will heat significantly and TFT brightness will lower.
Threads: 5
Hi, After the construction of the pro 2 plus receiver, the transmitter, the 4pro wireless display, and the AQM II transmitter, I tested everything and everything seems to work. The only doubt I have left is that, as soon as I turn on the pro 2 plus receiver, it starts the initialization sequence and does not complete it because, to the tx transmitter, I connected only a T/H sensor and not yet an anemometer and a rain gauge. Reading several articles in the forum, it seems that the pro 2 plus receiver completes the initialization only when it receives data from all three sensors. If it does not complete initialization, the touch display remains locked. Can you confirm it? Can I somehow simulate the connection of the two missing sensors in order to cheat the receiver and thus close the sequence? Thanks
