25-02-2015, 17:30
I've been thinking about the resistors in the RX, TX and WD where their values change depending on the LED's used. Would it be a good idea, where/when the LED's are not PCB mounted to replace the resistors with wire links and then solder the resistors into the wire links to the LED's. My thinking behind this is, that it will be easier to change the resistors in the wire links than it would be on the pcb especially as the solder pads are not that big and I would be afraid that resoldering would overtime would ware them out. I would interested on your thoughts about this.
regards
tyntop.
regards
tyntop.
