Threads: 38
Weather Station: B/L Weather Station
I have this issue now too (before it was without issue). It's probably been a few days. And I didn't change any configuration
of my devices. I think the API had to change?
Threads: 38
I tried to restart my WD and the error was lost.
(I tried it twice and then let WD run for more than an hour.)
Threads: 22
Weather Station: Wetterstation Engolling
Hello together,
I just did some tests with my WD unit.
For me it is working with each ESP board version as well as German and Polish language.
I get a lot of compiler warnings from the tft library.
Concerning the issues … could it be related to the Wifi connection? Signal quality or WPA key … just guessing.
I believe I found the problem, hopefully I will solve it up to next weekend. I may need some help from Jarek and Zdenek to tell me the exact range of extended chars used on Polish an Czech. I will send a PM to both about this matter.
engolling: The problem is more prone to happen with the Pro2 PLUS than with the WD units.
