Threads: 6
Weather Station: St Albans Weather
When I try to access the web site in the Pro2 Compact RX all I get is:
404: Not found.
I have Enable_Internet and Enable_Webserver both set to 1.
Have I missed something else.
Thank you
Philip
Threads: 31
Weather Station: Conder Weather, Canberra
Are you using the external or internal IP? Usless you're port forwarded the Internal IP, then the external IP won't work from within the internal network. I hope that makes sense lol. Anyway just use the internal IP and it should work.
Threads: 31
The PC is on this 192.168.1 network too?
Threads: 15
On the compact RX it's ip address /weather .
Threads: 15
I had to ask the same question when I moved from the Pro2 Plus to the Compact Rx, happy to help another user
