Threads: 15
So the wireless display will fit this also?
Threads: 337
Once the Pro2 Compact and the WiFi Wireless Display units use a PCB with the same size, and que SMA connector is on the same position in both boards, I believe this case can be used for both units.
Threads: 337
Each time it looks better!
The weight of the unit is somewhat concentrated in the front, so a base with an adjustable angle makes a lot of sense.
You are a master in 3D design!
Threads: 15
Yes agree, love the base
