Setting date and time problem
Cumulus log:
10.09.2018 01:42:40.054 : Firmware Version: 1.90
10.09.2018 01:42:40.054 : Discon period: 3
10.09.2018 01:42:40.054 : VP2: Setting station clock
10.09.2018 01:42:40.054 : y=2018 m=9 d=10 h=1 m=42
10.09.2018 01:42:41.828 : VP2: SetStationTime_V res = 0
10.09.2018 01:42:41.828 : VP2: Getting station clock
10.09.2018 01:42:42.405 : VP2: GetStationTime_V res = 0
10.09.2018 01:42:42.405 : y=2019 m=5 d=2 h=1 m=42
10.09.2018 01:42:42.405 : Loading last N hour data from data logs: 10.09.2018 01:41:01
10.09.2018 01:42:42.405 : Loaded 31 entries to last hour data list
10.09.2018 01:42:42.406 : Loaded 31 entries to last 3 hour data list
10.09.2018 01:42:42.407 : Loaded 31 entries to last 24 hour data list
10.09.2018 01:42:42.408 : Log file does not exist: C:\Cumulus\data\paź18log.txt
10.09.2018 01:42:42.408 : Log file does not exist: C:\Cumulus\data\lis18log.txt
10.09.2018 01:42:42.408 : Loaded 31 entries to recent data list
Is the RTC clock correctly detected by the I2C scanner utility?
Could you try running the system without connecting the ATM sensor?
It's idea!!!!  Idea
I'll check check when I get home.
I removed BME280 - no results  Angry
I2C Scanner:
776 -> Scanning...
17:49:42.852 -> I2C device found at address 0x50  !  <- Display
17:49:42.852 -> I2C device found at address 0x68  !  <- RTC DS3231
17:49:42.852 -> I2C device found at address 0x76  !  <- BME280
17:49:42.852 -> done
That's a very strange situation. Huh
If possible I suggest you to use the MultiSpeedI2CScanner.ino included on the software.
Or something is messing with the I2C communication, or the RTC modules are faulty.
It don't seems a problem in the I2C bus as the data from BME280 is read perfectly .
Just a small correction:
17:49:42.852 -> I2C device found at address 0x50  !  <- External EEPROM
Hmm....
Multi Speed I2C  Scanner:
TIME    DEC    HEX        50    100    200    300    400    [KHz]
00:26:09.859 -> --------------------------------------------------------------------------------
00:26:09.859 -> 51283    0    0x00        .    .    .    .    .
00:26:09.893 -> 51286    1    0x01        .    .    .    .    .
00:26:09.893 -> 51288    2    0x02        .    .    .    .    .
00:26:09.893 -> 51290    3    0x03        .    .    .    .    .
00:26:09.893 -> 51292    4    0x04        .    .    .    .    .
00:26:09.893 -> 51294    5    0x05        .    .    .    .    .
00:26:09.893 -> 51296    6    0x06        .    .    .    .    .
00:26:09.893 -> 51298    7    0x07        .    .    .    .    .
00:26:09.893 -> 51300    8    0x08        .    .    .    .    .
00:26:09.893 -> 51302    9    0x09        .    .    .    .    .
00:26:09.893 -> 51304    10    0x0A        .    .    .    .    .
00:26:09.893 -> 51306    11    0x0B        .    .    .    .    .
00:26:09.893 -> 51309    12    0x0C        .    .    .    .    .
00:26:09.893 -> 51311    13    0x0D        .    .    .    .    .
00:26:09.893 -> 51313    14    0x0E        .    .    .    .    .
00:26:09.893 -> 51315    15    0x0F        .    .    .    .    .
00:26:09.893 -> 51317    16    0x10        .    .    .    .    .
00:26:09.893 -> 51319    17    0x11        .    .    .    .    .
00:26:09.927 -> 51322    18    0x12        .    .    .    .    .
00:26:09.927 -> 51324    19    0x13        .    .    .    .    .
00:26:09.927 -> 51326    20    0x14        .    .    .    .    .
00:26:09.927 -> 51329    21    0x15        .    .    .    .    .
00:26:09.927 -> 51331    22    0x16        .    .    .    .    .
00:26:09.927 -> 51333    23    0x17        .    .    .    .    .
00:26:09.927 -> 51336    24    0x18        .    .    .    .    .
00:26:09.927 -> 51338    25    0x19        .    .    .    .    .
00:26:09.927 -> 51340    26    0x1A        .    .    .    .    .
00:26:09.927 -> 51342    27    0x1B        .    .    .    .    .
00:26:09.927 -> 51344    28    0x1C        .    .    .    .    .
00:26:09.927 -> 51346    29    0x1D        .    .    .    .    .
00:26:09.927 -> 51348    30    0x1E        .    .    .    .    .
00:26:09.927 -> 51351    31    0x1F        .    .    .    .    .
00:26:09.927 -> 51353    32    0x20        .    .    .    .    .
00:26:09.960 -> 51355    33    0x21        .    .    .    .    .
00:26:09.960 -> 51357    34    0x22        .    .    .    .    .
00:26:09.960 -> 51359    35    0x23        .    .    .    .    .
00:26:09.960 -> 51361    36    0x24        .    .    .    .    .
00:26:09.960 -> 51364    37    0x25        .    .    .    .    .
00:26:09.960 -> 51366    38    0x26        .    .    .    .    .
00:26:09.960 -> 51368    39    0x27        .    .    .    .    .
00:26:09.960 -> 51371    40    0x28        .    .    .    .    .
00:26:09.960 -> 51373    41    0x29        .    .    .    .    .
00:26:09.960 -> 51375    42    0x2A        .    .    .    .    .
00:26:09.960 -> 51378    43    0x2B        .    .    .    .    .
00:26:09.960 -> 51380    44    0x2C        .    .    .    .    .
00:26:09.960 -> 51382    45    0x2D        .    .    .    .    .
00:26:09.960 -> 51384    46    0x2E        .    .    .    .    .
51386    47    0x2F        .    .    .    .    .
00:26:09.994 -> 51388    48    0x30        .    .    .    .    .
00:26:09.994 -> 51390    49    0x31        .    .    .    .    .
00:26:09.994 -> 51393    50    0x32        .    .    .    .    .
00:26:09.994 -> 51395    51    0x33        .    .    .    .    .
00:26:09.994 -> 51397    52    0x34        .    .    .    .    .
00:26:09.994 -> 51399    53    0x35        .    .    .    .    .
00:26:09.994 -> 51401    54    0x36        .    .    .    .    .
00:26:09.994 -> 51403    55    0x37        .    .    .    .    .
00:26:09.994 -> 51406    56    0x38        .    .    .    .    .
00:26:09.994 -> 51408    57    0x39        .    .    .    .    .
00:26:09.994 -> 51410    58    0x3A        .    .    .    .    .
00:26:09.994 -> 51412    59    0x3B        .    .    .    .    .
00:26:09.994 -> 51415    60    0x3C        .    .    .    .    .
00:26:09.994 -> 51417    61    0x3D        .    .    .    .    .
00:26:10.028 -> 51420    62    0x3E        .    .    .    .    .
00:26:10.028 -> 51422    63    0x3F        .    .    .    .    .
00:26:10.028 -> 51424    64    0x40        .    .    .    .    .
00:26:10.028 -> 51426    65    0x41        .    .    .    .    .
00:26:10.028 -> 51428    66    0x42        .    .    .    .    .
00:26:10.028 -> 51430    67    0x43        .    .    .    .    .
00:26:10.028 -> 51432    68    0x44        .    .    .    .    .
00:26:10.028 -> 51435    69    0x45        .    .    .    .    .
00:26:10.028 -> 51437    70    0x46        .    .    .    .    .
00:26:10.028 -> 51439    71    0x47        .    .    .    .    .
00:26:10.028 -> 51441    72    0x48        .    .    .    .    .
00:26:10.028 -> 51443    73    0x49        .    .    .    .    .
00:26:10.028 -> 51445    74    0x4A        .    .    .    .    .
00:26:10.028 -> 51448    75    0x4B        .    .    .    .    .
00:26:10.028 -> 51450    76    0x4C        .    .    .    .    .
00:26:10.028 -> 51452    77    0x4D        .    .    .    .    .
00:26:10.028 -> 51454    78    0x4E        .    .    .    .    .
00:26:10.062 -> 51457    79    0x4F        .    .    .    .    .
00:26:10.062 -> 51459    80    0x50        V    V    V    V    V
00:26:10.062 -> 51462    81    0x51        .    .    .    .    .
00:26:10.062 -> 51464    82    0x52        .    .    .    .    .
00:26:10.062 -> 51466    83    0x53        .    .    .    .    .
00:26:10.062 -> 51468    84    0x54        .    .    .    .    .
00:26:10.062 -> 51470    85    0x55        .    .    .    .    .
00:26:10.062 -> 51472    86    0x56        .    .    .    .    .
00:26:10.062 -> 51474    87    0x57        .    .    .    .    .
00:26:10.062 -> 51477    88    0x58        .    .    .    .    .
00:26:10.062 -> 51479    89    0x59        .    .    .    .    .
00:26:10.062 -> 51481    90    0x5A        .    .    .    .    .
00:26:10.062 -> 51483    91    0x5B        .    .    .    .    .
00:26:10.062 -> 51485    92    0x5C        .    .    .    .    .
00:26:10.062 -> 51487    93    0x5D        .    .    .    .    .
00:26:10.097 -> 51490    94    0x5E        .    .    .    .    .
00:26:10.097 -> 51492    95    0x5F        .    .    .    .    .
00:26:10.097 -> 51494    96    0x60        .    .    .    .    .
00:26:10.097 -> 51496    97    0x61        .    .    .    .    .
00:26:10.097 -> 51499    98    0x62        .    .    .    .    .
00:26:10.097 -> 51501    99    0x63        .    .    .    .    .
00:26:10.097 -> 51504    100    0x64        .    .    .    .    .
00:26:10.097 -> 51506    101    0x65        .    .    .    .    .
00:26:10.097 -> 51508    102    0x66        .    .    .    .    .
00:26:10.097 -> 51510    103    0x67        .    .    .    .    .
00:26:10.097 -> 51513    104    0x68        V    V    V    V    V
00:26:10.097 -> 51515    105    0x69        .    .    .    .    .
00:26:10.097 -> 51517    106    0x6A        .    .    .    .    .
00:26:10.097 -> 51519    107    0x6B        .    .    .    .    .
00:26:10.097 -> 51521    108    0x6C        .    .    .    .    .
00:26:10.097 -> 51524    109    0x6D        .    .    .    .    .
00:26:10.131 -> 51526    110    0x6E        .    .    .    .    .
00:26:10.131 -> 51528    111    0x6F        .    .    .    .    .
00:26:10.131 -> 51530    112    0x70        .    .    .    .    .
00:26:10.131 -> 51533    113    0x71        .    .    .    .    .
00:26:10.131 -> 51535    114    0x72        .    .    .    .    .
00:26:10.131 -> 51537    115    0x73        .    .    .    .    .
00:26:10.131 -> 51539    116    0x74        .    .    .    .    .
00:26:10.131 -> 51543    117    0x75        .    .    .    .    .
00:26:10.131 -> 51545    118    0x76        V    V    V    V    V
00:26:10.131 -> 51547    119    0x77        .    .    .    .    .
00:26:10.131 -> 51549    120    0x78        .    .    .    .    .
00:26:10.131 -> 51552    121    0x79        .    .    .    .    .
00:26:10.131 -> 51554    122    0x7A        .    .    .    .    .
00:26:10.131 -> 51556    123    0x7B        .    .    .    .    .
00:26:10.166 -> 51558    124    0x7C        .    .    .    .    .
00:26:10.166 -> 51561    125    0x7D        .    .    .    .    .
00:26:10.166 -> 51563    126    0x7E        .    .    .    .    .
00:26:10.166 -> 51565    127    0x7F        .    .    .    .    .
00:26:10.166 ->
00:26:10.166 -> 3 devices found in 290 milliseconds.
00:26:10.166 ->
(10-09-2018, 23:30)jarekh3 Wrote:  Hmm....
00:26:10.166 ->
00:26:10.166 ->
Aaaa..... This is a message with an extended DS3231 (Without RTC):
ESP8266 FW Version: WIFI GOT IP
00:39:19.708 -> AT+GMR
00:39:19.708 -> AT version:1.3.0.0(Jul 14 2016 18:54:01)
00:39:19.743 -> SDK version:2.0.0(5a875ba)
00:39:19.743 -> Farylink Technology Co., Ltd. v1.0.0.2
00:39:19.778 -> May 11 2017 22:23:58
00:39:19.778 -> OK
Mode station OK
00:39:26.272 -> Multiple mux OK
Join AP success!
00:39:31.301 -> Connected to AP: AT+CWJAP?
00:39:31.301 -> +CWJAP:"morska1","e8:de:27:cd:52:35",6,-65
00:39:31.336 ->
00:39:31.336 -> OK
00:39:31.336 ->
00:39:31.336 -> IP Address: 192.168.1.116
00:39:31.370 -> Broadcast IP: 192.168.1.255
00:39:31.370 -> Start tcp server OK
STATUS:2
00:39:31.439 -> Set tcp server timout 30 seconds
00:39:31.474 -> RTC current date: Apr 24 2018
00:39:31.474 -> RTC current time: 23:46:39
00:39:31.509 -> Sending NTP request to sync clock...
NTP replied
00:39:31.613 -> UTC time from NTP server: 22:39:29
00:39:31.613 -> RTC adjusted to local time: 23:39:29
WiFi connection is ON
Quote:Aaaa..... This is a message with an extended DS3231 (Without RTC):
Sorry I don't understand what you mean, can you please explain it better...
Trying to guess... even if the RTC module isn't attached to the board, software always output some values here:
The software doesn't check or produce any error message in case the RTC module isn't present or not working.
We can discard any problem with RX software because it is working for many others, including myself. Whatever is happening its an hardware problem. My best bet is that the RTC modules are faulty.
Try to test them using a breadboard and a spare Arduino (or use the Nano installed on the TX unit).
Exactly, I received this message after removing the RTC from the plate. (Plate without DS3231):
NTP replied
Well, I'm ordering another RTC.
I am a happy owner of four modules DS3231  Smile
Each bought at different store. When you start the Weatherduino chip is set to the correct date and time by NTP (ignoring the hour shift (?))
but the displayed  the date 8-04-2018.
This module when it is connected to another Arduino shows the correct date and time on LCD (e.g. 16-09-2018 21:45).
[Image: 9246329be9db.jpg]
When I connect Cumulus Weatherduino adjust correctly time only on the display (eliminates the hour offset) but the date is in the format e.g.. 222-05-2019 and the RTC when connected to the reference turns out to be reset and shows 01-01-2000 00:00.
Cumulus log:
16.09.2018 21:52:08.817 : Discon period: 3
16.09.2018 21:52:08.817 : VP2: Setting station clock
16.09.2018 21:52:08.817 : y=2018 m=9 d=16 h=21 m=52
16.09.2018 21:52:10.190 : VP2: SetStationTime_V res = 0
16.09.2018 21:52:10.190 : VP2: Getting station clock
16.09.2018 21:52:10.771 : VP2: GetStationTime_V res = 0
16.09.2018 21:52:10.771 : y=2019 m=5 d=8 h=21 m=52
16.09.2018 21:52:10.771 : Loading last N hour data from data logs: 16.09.2018 19:36:00
Sketch from RTClib library sets correctly DS3231 both on the WeatherDuino and reference the layout of the Arduino Mega.
I removed the BME280 and put SHT21 and its indication of T/H are also valid.
All this happens on a clean install of Weatherduino v. 7 and is independent of the settings of the longitude and latitude or time zone.
I do not understand why the program ignores my time zone settings.
TimeChangeRule PST = {"PST", Last, Sun, Mar, 1, 120};   //Portuguese Summer Time -  "UTC + 1" or GMT + 1
TimeChangeRule GMT = {"GMT", Last, Sun, Oct, 2, 60};    //Portuguese Winter Time -  "UTC + 0" or GMT
Timezone myTZ(PST, GMT);
Slowly end to me ideas, replace the EEPROM, Meduino, whether to buy a fifth RTC?
