05-04-2017, 21:07
I'm playing with Pro2 plus RX and Tx with Soil/Leaf interface.
OneWire connected to S1 and L1.
It's working on Rx dedicated screen:
But on web server S1 and L1 temp data are missing:
My config file:
Did i miss something in the config ?
I think it should perhaps be because i only define TempSensors (Soil/Leaf) and NO SoilMoist or LeafWet sensors !
Laurent
My config file:
// WeatherDuino Pro2 PLUS - Version: 2.00 b018
// Start of user configurable options
// Define Name and ID's for this weather station
const char WeatherStation_Name[] = "MeteoMeyenheim";
#define Station_ID 0x1B // Station_ID, use the same value in all TX units
#define Relay_ID 0xB3 // Relay_ID, use the same value in all WD units
// Define your Weather Station location
#define LATITUDE 479 // Put here your Station latitude in tenths of degrees North
#define LONGITUDE 73 // Put here your Station longitude in tenths of degrees (minus for West)
#define ELEVATION 208 // Put here your Station height above sea level in Meters
// Define rules for Auto Summer Time Display, and clock adjustment
// TimeChangeRule aEDT = {"AEDT", First, Sun, Oct, 2, 660}; //UTC + 11 hours
// TimeChangeRule aEST = {"AEST", First, Sun, Apr, 3, 600}; //UTC + 10 hours
// Timezone myTZ(aEDT, aEST);
//TimeChangeRule PST = {"PST", Last, Sun, Mar, 1, 60}; //Portuguese Summer Time - "UTC + 1" or GMT + 1
//TimeChangeRule GMT = {"GMT", Last, Sun, Oct, 2, 0}; //Portuguese Winter Time - "UTC + 0" or GMT
TimeChangeRule PST = {"PST", Last, Sun, Mar, 1, 120}; // Summer Time - "UTC + 2" or GMT + 2
TimeChangeRule GMT = {"GMT", Last, Sun, Oct, 2, 60}; // Winter Time - "UTC + 1" or GMT + 1
Timezone myTZ(PST, GMT);
// Define Roll Over Hour for Meteorological Day
#define MeteoDay_HStart 0 // Use values from 0 to 23
// Define your Display type
#define DisplayType 3 // 1= LCD 20x4, 3= TFT 320x240 ILI9341
// Define Display Backlight TimeOut
const byte BackLight_Timeout = 60; // Timeout for display backlight in minutes (1 to 255). 0 = Always ON
#define Use_ScreenSaver 1 // Instead of turn off TFT backlight show a big clock screen. 0= No, 1= Yes
// Define data display units
#define Date_Time_Format 0 // 0 for dd-mm-yyyy, 1 for yyyy/mm/dd
byte Temp_Display_Unit = 0; // 0 for ºC, 1 for ºF
byte ATM_Display_Unit = 0; // 0 for mBar, 1 for inHg
byte Rain_Display_Unit = 0; // no setting, always mm
byte Wind_Display_Unit = 0; // 0 for Km/h, 1 for mph, 2 for m/s, 3 for Knots
// Define the type of your Barometric Pressure Sensor
#define Barometric_Sensor 0 // 0= BME280, 1= BMP280 2= BMP085 / BMP180
// Define the type of your inside Temperature / Humidity Sensor
#define InsideTH_Sensor 0 // 0= BME280, 1= HTU21D, 2= SHT21, 3= SHT31
// Fine adjusts for Inside Temperature and Barometer
const int TemperaturaInt_offset = 0; // Inside Temperature Fine Adjust in Tenths of Degree (-4 = -0,4ºC)
const float pressure_offset = 0; // Pressure Fine Adjust in mB
// Define the type of your outside Temperature / Humidity Sensor
#define MainOutTH_Sensor 0 // 0 for sensor type SHT31, SHT21 or HTU21D, 1 for sensor type SHT1x or DHT22
// Define Wind Speed and Wind Gust resolution
// This setting only have effect when the software is used in Davis VP emulation mode
#define VP2_WindRes 2 // If set to 2, set Cumulus Wind Speed and Wind Gust multipliers to 0.448. Wind Resolution 0.72 Km/h
// WARNING !!! Setting this variable to 1 allows a better wind speed and gust resolution,
// but also limits both of them, to a maximum reading of just 91.8 Km/h
// If set to 0, system uses Standard Davis wind resolution (1 mph or 0.1mph with LOOP2).
// Weather Display users should set this option to 0 - Standard Davis wind resolution
// Define use of Wind Gust Spike prevention routines (mostly for FO anemometers)
#define WindSpikeControl 1 // 0= Disable, 1= Enable
// Define the source of your main outside sensors
#define TH_OutUnit 0 // 0= Temp/Hum sensor connected to TX_Unit 0, 1= Temp/Hum sensor connected to TX_Unit 1, ...
#define WIND_OutUnit 0 // 0= Wind instruments connected to TX_Unit 0, 1= for TX_Unit 1, ...
#define RAIN_OutUnit 0 // 0= Rain Gauge connected to TX_Unit 0, 1= for TX_Unit 1, 3 for Auriol RF Rain Gauge
// ---- Define the source of your main Solar / UV sensores
#define SRUV_OutUnit 9 // 0= Solar Rad / UV sensors connected to TX_Unit 0, 1= for TX_Unit1, 9 for not used
// ---- Define type of Solar Radiation / UV Sensors
// ---- Support for Solar Radiation sensor type 2 and UV sensor type 4 (it is a PAR sensor not a UV Sensor) still are experimental
#define Solar_Sensor 1 // 0 not used, 1= Solar Cell "Pyranometer", 2= Apogee SP-110: Self-Powered Pyranometer
#define UV_Sensor 1 // 0 not used, 1= UVM-30A, 2= Reserved, 3= Reserved, 4= Apogee SQ-110: Photosynthetically Active Radiation Sensor
#define UV_Transmission 75 // UV Transmission percentage of UV sensor cover material
// Extra Sensors Settings and Mapping
// ---- Define the source and sensor type (number) for each of the seven extra sensors, insert 9 if not used.
// Sensors SHT31, SHT21 or HTU21D are type 0, sensors SHT1x or DHT22 are type 1
// ---- Source 0 means TX unit0, 1 means TX unit1...
// ---- Source 6 (Reserved)
// ---- Source 7 is for BIOS Sensor (Only Temperature is shown)
// ---- Source 8 is for Air Quality Monitor. 0= Temperature/Humidity, 1= Dust Density/AQI
// ---- (AQI sensors can be mapped to any position, but should be mapped in sequence, Temperature/Humidity always first)
// ---- First field = Sensor source, Second field = Sensor type (0 or 1 for TX units)
// ---- Example:
// ---- ES0 ES1 ES2 ES3 ES4 ES5 ES6
//#define ExtraSensors_Source { {0,1},{1,1},{9,9},{6,3},{9,9},{8,0},{8,1} }
// {0,1} - First extra sensor (ES0), will be sensor 1 from TX unit0
// {1,1} - Second extra sensor (ES1), will be sensor 1 from TX unit1
// {9,9} - Third extra sensor (ES2), not used - not mapped
// {6,3} - Fourth extra sensor (ES3), will be OneWire sensor number 3 (OneWire sensors are numbered from 0 to 3)
// {9,9} - Fifth extra sensor (ES4), not use - not mapped
// {8,0} - Sixth extra sensor (ES5), will be Temperature / Humidity from the Air Quality Monitor
// {8,1} - Seventh extra sensor (ES6), will be Dust Density / AQI index from the Air Quality Monitor
//----- ES0 ES1 ES2 ES3 ES4 ES5 ES6
#define ExtraSensors_Source { {5,9},{5,9},{5,9},{5,9},{5,9},{0,1},{7,0} }
// ---- Define personalized names for each Extra sensor. Attention, maximum 8 chars
#define ExtraSensor1_Name "Cave"
#define ExtraSensor2_Name "Cellier"
#define ExtraSensor3_Name "Chambre"
#define ExtraSensor4_Name "Schirla"
#define ExtraSensor5_Name "Soute"
#define ExtraSensor6_Name "SENSOR 5"
#define ExtraSensor7_Name "Dust/AQI"
#define DomoSensor1_Name "Domo1"
#define DomoSensor2_Name "Domo2"
#define DomoSensor3_Name "Domo3"
#define DomoSensor4_Name "Domo4"
#define DomoSensor5_Name "Domo5"
#define DomoSensor6_Name "Domo6"
#define DomoSensor7_Name "Domo7"
// BIOS soil moisture sensor settings
#define BiosSensor_ID 0 // Device ID in HEX format, or 0 not used
// Soil / Leaf Interface Settings and Sensors Mapping
// (The mapping logic is the same than used with the Extra Sensors)
// 0 = Soil Leaf Interface not used
#define SoilLeaf_Interface 1 // 0, 1,
// S1 S2 S3 S4
#define SoilTempSensors_Source { {0,0},{9,9},{9,9},{9,9} }
#define LeafTempSensors_Source { {0,1},{9,9},{9,9},{9,9} }
#define SoilMoistSensors_Source { {9,9},{9,9},{0,2},{9,9} }
#define LeafWetSensors_Source { {9,9},{9,9},{9,9},{0,3} }
// ---- Define personalized names for each Soil and Leaf sensor. Attention, maximum 8 chars
#define SoilSensor1_Name "S1"
#define SoilSensor2_Name "S2"
#define SoilSensor3_Name "S3"
#define SoilSensor4_Name "S4"
#define LeafSensor1_Name "L1"
#define LeafSensor2_Name "L2"
#define LeafSensor3_Name "L3"
#define LeafSensor4_Name "L4"
// Define VWC calculation method
// at http://www.vegetronix.com/Products/VH400/VH400-Piecewise-Curve.phtml
#define VWC_CalcMethod 1
// Max and Min output voltage of the analog sensors connected to Soil / Leaf Interface
// Default value for Decagon Devices LWS Leaf Wetness Sensor (3.3V power): Max. Output Voltage - 1395mV (max wetness), Min Output Voltage - 530mV (dry)
// ADC1 ADC2 ADC3 ADC4
const unsigned int AnalogSensor_MaxVoltOut[4] = { 3000, 1395, 5000, 5000 }; // Values in miliVolts
const unsigned int AnalogSensor_MinVoltOut[4] = { 0, 530, 0, 0 };
// Broadacasting settings for Wireless Display Units
#define Relay_Data 1 // 0= Disables Data Relay, 1= Enables Data Relay
// Davis compatible Data Logger Settings
#define Logger_Enable 1 // 0= Disable 1= Enable
byte ARCHIVE_PERIOD = 5; // Default Archive Period in Minutes (Usable values: 1, 5, 10, 15, 30)
// Easyweather format data Output
#define Easyweather_Out 0 // 0= Disable (defaut) 1= Enable
// Internet Settings
#define Enable_Internet 1 // 1= Enable Internet connection, 0= Disable
//#define SSID "----"
//#define PASSWORD "----"
#define Enable_NTP 1 // 1= Enable Sync time with NTP servers, 0= Disable
// NTP Server:
#define timeServer "time.nist.gov" // ntp1.nl.net NTP server
//#define timeServer "80.96.196.58" // timp.mcsi.ro
//#define timeServer "193.79.237.14" // ntp1.nl.net NTP server
// Weather Wunderground Settings
#define Enable_WUupload 0 // 1= Enable upload to Wunderground, 0= Disable
#define WUupload_period 6 // Period in minutes between uploads to WU (avoid use less than 3 minutes)
#define WUupload_InTemp 0 // 1= Enable upload of Inside Temperature / Humidity, 0= Disable
// ---- Wunderground Personal Data
#define WUNDERGROUND_STATION_ID "----" // Weather Underground station ID
#define WUNDERGROUND_PWD "----" // Weather Underground password
// Web Server Settings
#define Enable_WebServer 1 // 1= Enable 0= Disable
#define WebServer_port 80 // WebServer port (default 80)
#define Enable_DomoData 1
// Enable / Disable GPIO routines - General Purpose Input / Output ports
#define UseGPIO 0 // 0=Disable, 1= Enable
// Test Mode : Never run a live system in test mode
#define TestMode false // false= Normal working mode, true= Test mode only (no logger, no usb connection)
// Hardware settings
// ---- Define LCD I2C address
// Only change this if your LCD don't display any data. I2C_Scanner utility may help you to find the address of your LCD display
#define LCD_I2C_Address 0x27
// SHT31 I2C Address - Default address will work most of the times!
#define SHT31_address 0x44 // Default value is 0x44, but it can be changed to 0x45
// Presure Sensor Address (no need to change)
//#define BMP085_ADDRESS 0x77 // I2C address of BMP085 or BMP180
// Debug helper
//#define PRINT_DEBUG_NTP_UPDATE // Prints to serial monitor messages related to sync time with NTP server
//#define PRINT_DEBUG_WU_UPLOAD // Prints to serial monitor messages related to Weather Underground upload.
//#define PRINT_DEBUG_TCP_SERVER
//#define PRINT_DEBUG_AURIOL
//#define PRINT_DEBUG_BIOS
// End of user configurable options
Laurent
