Threads: 4
Hello,Do you know how to connect the new Davis 6410 anenometer. The cable has 4 pins (black ,red , green , yellow). I can get the speed but not the direction. This remains frozen at a value.
Thanks.
Threads: 4
Now, it's like ok with my cable.
Regards.
Threads: 4
Hello, How to adjust the degree vane offset ?
Regards.
Threads: 27
Weather Station: WeatherDuino Pro2
01-06-2020, 01:20
(This post was last modified: 01-06-2020, 22:16 by
JT118.)
This a manual thing, you need to undo the very small Allen screw and turn the vane on the potentiometer shaft until it points North and shows up on the display as North, then tighten up Allen Screw.
Being American the Allen Key is probably still imperial and 0.05"
