I have attached a revised Excel spreadsheet with calculations. Changes made now approach the 3A per day mark and seem more close to reality.
A few questions, so I can further improve the needs estimation:
- How often are readings taken then? Every 3 seconds?
- Can you please share the settings you are using (temperature and wind speed set points) to turn the fan on? This would allow me to simulate behavior by using one year of past meteo data.
- I do not seem to see power being supplied to the Wind Cups and RainMeter. Am I correct to assume these will produce an electrical impulse on their own using motion?
Anyway, with what I know so far, having established my needs to be an average 2,668 Amps per day (11,7 Kwh per year), I have played with
PV*SOL simulating different
set-ups for my location (Lisbon, which as you might know is fairly sunny by European standards).
The conclusions on the safe side seem to be:
A 10 Watts panel is not enough no matter the battery used. From November to February the output seriously risks to be bellow the average consumption.
One should look for at least a 15 Watts solar panel.
You can get along with a 15Ah battery provided you couple it with a 20W or plus solar panel.
Those looking for complete piece of mind should get a 20W panel (~1.3A * 3 conventional full sun hours, considered for design purposes = 3.9 Amps per day reference production. Subtract cable + solar regulator + battery in & out loses)
and a 20-24Ah battery (~4 days of autonomy, discharge treshold of 50%). This should be able to meet the needs under all scenarios.
Just for the sake of it I also did a simulation using meteo data for Glasgow (Airport), as I believe the weather is particularly gloomy there.
This shows that even a 20W panel with a 24Ah battery would be insufficient in Scotland, the problem being the months from October to March (notice the orange line in the attached graph).
Piece of mind using sun power exclusively there under a worst case scenario seems it would mean using around 60 to 72 Watts of solar panels with a similar battery (24Ah).
