This forum uses cookies
  • 0 Votes - 0 Average
RTC module - Assembly hints
Some hints to assemble the RTC module in a v3.0x RX board and get a perfect fit.
Take a 4 pin right angle connector.
[Image: RTC_assembly_01.jpg]
Insert it, with the long pins in the RTC module as show in picture below.
Solder and cut pins in excess.
[Image: RTC_assembly_02.jpg]
Insert the RTC module in the RX board as show in picture below.
Only solder the RTC module after all other parts are assembled.
[Image: RTC_assembly_03.jpg]
