Hello Toby,
When the CO2 sensor is installed and enabled in the software, the CO2 readings will be show on the OLED display.
// Define type of CO2 sensor
#define CO2_SENSORTYPE 1 // 0= Not instaled, 1= Sensirion SDC30, 2= MH-Z19
// Settings for the Sensirion SCD30 - CO2 Sensor
// The sensirion SDC30 compensate the CO2 readings by using one of two methods: Atmospheric Pressure or a fixed Altitude value.
// Define bellow which one you want to use.
#define SDC30_ELEVATION_CALIBRATION_METHOD 1 // 0= Elevation defined above, 1= Atmospheric Pressure from BME280 sensor (overrides ELEVATION)
// If the SDC30 is intalled, system will use its high quality built-in Temperature / Humidity sensor. BME280 will be used only for Atmospheric Pressure.
// Optionally we can set a temperature offset up to 5.0 °C, stored in non-volatile memory of SCD30
const float SCD30_TemperatureOffset = 2.0; // Format: float
