OLED - Printable Version
+---- Thread: OLED (/thread-2094.html)
OLED - tobyportugal - 08-10-2021
A question that may seem silly to you.
On an indoor AQM III with an OLED: the display supports PM2.5/10 and AQI. Is it possible to display CO (SCD30)?
[Image: attachment.php?aid=2913]
RE: OLED - werk_ag - 08-10-2021
Hello Toby,
When the CO2 sensor is installed and enabled in the software, the CO2 readings will be show on the OLED display.
// -------------------------------------------------------------------------------------- // Define type of CO2 sensor // -------------------------------------------------------------------------------------- #define CO2_SENSORTYPE 1 // 0= Not instaled, 1= Sensirion SDC30, 2= MH-Z19 // -------------------------------------------------------------------------------------- // Settings for the Sensirion SCD30 - CO2 Sensor // -------------------------------------------------------------------------------------- // The sensirion SDC30 compensate the CO2 readings by using one of two methods: Atmospheric Pressure or a fixed Altitude value. // Define bellow which one you want to use. #define SDC30_ELEVATION_CALIBRATION_METHOD 1 // 0= Elevation defined above, 1= Atmospheric Pressure from BME280 sensor (overrides ELEVATION) // If the SDC30 is intalled, system will use its high quality built-in Temperature / Humidity sensor. BME280 will be used only for Atmospheric Pressure. // Optionally we can set a temperature offset up to 5.0 °C, stored in non-volatile memory of SCD30 const float SCD30_TemperatureOffset = 2.0; // Format: float
RE: OLED - tobyportugal - 09-10-2021
(08-10-2021, 19:44)Werk_AG Wrote:  Hello Toby,
Like
