Home Assistant
Thanks Werk.
No problem.
As a side note, I'm using Json to get AQM II data into PRTG.
Hope you're New Year is off to a nice start.
Cheers,
UB
(07-01-2024, 10:21)uncle_bob Wrote:  Here's the data I'm using so far.
[Image: Screenshot%202024-01-07%20200729.png]
Since the image is not visible, I decided to supplement this solution with an even more detailed guide:
1) definition in CumulusMX software
2) definitions, for example, in the file /homeassistant/mqtt.yaml (here it is in Czech language)
# MQTT - CumulusMX
sensor:
  - name: "Teplota vzduchu"
    state_topic: "CumulusMX/Interval"
    suggested_display_precision: 1
    unit_of_measurement: "°C"
    value_template: "{{ value_json.temp }}"
  - name: "Vlhkost"
    unit_of_measurement: "%RH"
    value_template: "{{ value_json.humidity }}"
  - name: "Rychlost větru"
    state_topic: "CumulusMX/DataUpdate"
    unit_of_measurement: "m/s"
    value_template: "{{ value_json.windspeed }}"
  - name: "Směr větru"
    unit_of_measurement: "°"
    value_template: "{{ value_json.winddir }}"
  - name: "Nárazy"
    value_template: "{{ value_json.wgust }}"
  - name: "Sluneční radiace"
    unit_of_measurement: "W/m2"
    value_template: "{{ value_json.SolarRad }}"
  - name: "UVI"
    unit_of_measurement: ""
    value_template: "{{ value_json.UVI }}"
  - name: "Srážky"
    unit_of_measurement: "mm"
    value_template: "{{ value_json.rfall }}"
  - name: "Intenzita srážek"
    unit_of_measurement: "mm/h"
    value_template: "{{ value_json.rrate }}"
3) result "text"
and definition of Entity card
type: entities
entities:
  - entity: sensor.teplota_vzduchu
    icon: mdi:thermometer
    secondary_info: last-updated
  - entity: sensor.vlhkost
    icon: mdi:water-percent
  - entity: sensor.rychlost_vetru
    icon: mdi:weather-windy
  - entity: sensor.smer_vetru
    icon: mdi:directions-fork
  - entity: sensor.narazy
    icon: mdi:windsock
  - entity: sensor.uvi
    icon: mdi:sun-wireless
  - entity: sensor.slunecni_radiace
    icon: mdi:sun-angle
  - entity: sensor.srazky
    icon: mdi:weather-rainy
  - entity: sensor.intenzita_srazek
theme: Animated Weather Card
state_color: true
title: Údaje meteo stanice
show_header_toggle: false
4) example of graphic processing
and its definition
type: history-graph
entities:
title: Meteo stanice
hours_to_show: 12
5) finally, a preview of the functionality of my MQTT server using MQTT Eplorer
I'll add: this is what my weather data page in HA looks like as of today...
(22-11-2024, 00:36)hornychz Wrote:  I'll add: this is what my weather data page in HA looks like as of today...
Nice! Looks a lot neater than mine Smile
