Daylight Savings Time
OK that's answers everything Big Grin Thanks for the assistance everyone.
(05-11-2017, 08:22)danner Wrote:  Noticed a glitch in the matrix.
Seems that the matrix is fine, it's me who's having glitches...  Blush
Quick question.
In Cumulus MX under "Settings>Station settings>options" there is a selection for "Synchronise station clock. Keep station clock in line with computer clock (Davis/Instromet only)"
Does this setting do anything to the Pro2+ receiver?
TIA
Yes, it syncs the station clock every day at 4AM. It's usefull to everyone which have Pro2 receivers, or Pro2 PLUS receivers that isn't using the sync to a NTP server.
(07-11-2017, 15:56)Werk_AG Wrote:  Yes, it syncs the station clock every day at 4AM. It's usefull to everyone which have Pro2 receivers, or Pro2 PLUS receivers that isn't using the sync to a NTP server.
Could that explain why my receiver time was changing back and forth by 1 hour since the time change was incorrectly set in my receiver?
I have an RTC in my receiver. Should I turn off the Cumulus MX "synchronize station clock" feature or just leave it on? I guess if everything is set correctly it shouldn't make a difference.
Hi danner,
I'm not thinking too much about it like you ... Smile  At Raspbian (CumulusMX) I have NTP sync turned on and on my RX+ also.
So why do they still sync with each other? I just turned it off and I never had any problem ...
[Image: Time.jpg]
Thanks, Zdenek.
(05-11-2017, 08:22)danner Wrote:  I'm still running v320_b002 because it has been raining and cold and I'm not changing the software on the TX until spring so I haven't changed the receiver software either.
Supossing your TX software is at least v3.xx, you can upgrade the RX to v4.xx without upgrading the TX software.
