AQMll max cabling distances
HI
Just received all the goodies I ordered  Thanks !
I am having difficulty in deciding the location of the SDS011 sensor  wrt the AQM11 pcb.
The SDS011 uses serial comms, however it is only +5 to 0V,  not +- V as per standard.
Please can anyone tell me the maximum advisable distance between the ESP8266 and the SDS011, with reliable communication.  Practical experience would be useful!
I would like to be able to choose a location for the sensor and AQMll and make off the correct length of cable with plugs and sockets and not have to do it twice!
many thanks
Patrick
Hello Patrick,
My experience always says to make cables as short as possible. In this case, it would mean a maximum of about 1/4 meter.
But I don't know the exact answer to your question...
An example of this is the image of my oldest version of AQM:
[Image: DSC_7444-upr-sm.jpg]
Or a picture of a 3D print on our WiKi (but Jarek has not yet published a program):
That means: all in one box.
Hi Patrick,
As Zdenek said, the shorter the cable the better. I would nor go for longer than 25 cm.
Let me give some hints:
- Install everything on the same box.
- The air intake on the SDS011 sensor is on the back. There is an adapter for a tube. If you wish, you can attach a small plastic tube and extend it to outside of the box (take care for water not get in).
[Image: sds011-large.png]
- Connect sensor this way:
AQMII  --  SDS011
SET ->    RXD
TX   ->    TXD
GND ->    GND
5V   ->    5V
