AQMll max cabling distances - Printable Version
+--- Forum: General Talking (
https://www.meteocercal.info/forum/Forum-General-Talking)
+--- Thread: AQMll max cabling distances (
/Thread-AQMll-max-cabling-distances)
Superpat - 20-04-2019
HI
Just received all the goodies I ordered Thanks !
I am having difficulty in deciding the location of the SDS011 sensor wrt the AQM11 pcb.
The SDS011 uses serial comms, however it is only +5 to 0V, not +- V as per standard.
Please can anyone tell me the maximum advisable distance between the ESP8266 and the SDS011, with reliable communication. Practical experience would be useful!
I would like to be able to choose a location for the sensor and AQMll and make off the correct length of cable with plugs and sockets and not have to do it twice!
many thanks
Patrick
RE: AQMll max cabling distances -
hornychz - 20-04-2019
Hello Patrick,
My experience always says to make cables as short as possible. In this case, it would mean a maximum of about 1/4 meter.
But I don't know the exact answer to your question...
An example of this is the image of my oldest version of AQM:
Or a picture of a 3D print on our WiKi (but Jarek has not yet published a program):
That means: all in one box.
werk_ag - 20-04-2019
Hi Patrick,
As Zdenek said, the shorter the cable the better. I would nor go for longer than 25 cm.
Let me give some hints:
- Install everything on the same box.
- The air intake on the SDS011 sensor is on the back. There is an adapter for a tube. If you wish, you can attach a small plastic tube and extend it to outside of the box (take care for water not get in).
- Connect sensor this way:
AQMII -- SDS011
SET -> RXD
TX -> TXD
GND -> GND
5V -> 5V
