Threads: 337
Country:
Hi geri12,
Keep us informed about your progress. Any development is welcome.
Does your modified code run on an Arduino Nano?
Can it deal with multiple TX units? Two-way communication may not be very useful for this matter.
Threads: 1
Weather Station: Davis vantage pro2, Ecowitt
Country:
Hi
Oks. This week you can modify the program. I use atmega644 (with arduino sketch). If the program memory is enough for the ATmega328, Arduino Nano can also be run. Multiple TX units not problem. Easy to do...
Threads: 337
Country:
Hi jeri12,
I always encourage any development or modification that everyone wants to do with the WeatherDuino Pro2 for it's own use, but that doesn't mean that I will gonna work on someone's code.
In this particular case, I really haven't the intention to change the type of RF link between the TX and RX units. There are several reasons for this, one of them is very important to me: backward compatibility!
There are around two hundreds of WeatherDuino Pro2 installations, I think that users will appreciate this concern. Despite the several enhancements introduced along the years, current software still work with early hardware boards.
By other way, almost all brands of weather stations, still use simple, one way RF links.
Threads: 31
Weather Station: Conder Weather, Canberra
Country:
Just a side note that this months' (September) SiliconChip magazine has a reader submitted short "Circuit ideas" article using NRF2401s' transceivers on ATMEGA328P microprocessors. The author says he get 1.5km with a BiQuad antenna.
Threads: 337
Country:
Shred, I fully agree with you. The 2.4Mhz don't seems to me the route to follow. If I ever think about changing the WeatherDuino Pro2 RF modules, probably the choice will be the RFM96. They allow to choose the operating frequency according to the legislation of each country, and there is even an high power version.
Threads: 1
Country:
Hi!
I have done it. I use RF24L01. The transmitter power setting under 10mW. (It's legal... plenty) My country allowed maximum power is 100mW. (2,4Ghz band). I talked to other "diy builders", and they are also used this unit (PA+LNA version) without any problems. Non-interference in other devices (game controller, keyboard, mouse, etc...).
Otherwise... I used two months of 433MHz transmitter with amplifiers, but the 2.4GHz is better. (me)
