Problem with WD
All has been going well but today my WD is not receiving all the data from the Rx
My receiver is getting data from the TX unit as the Rx led flashes at least every three seconds and the display is definitely updating.
I understand that it takes some time, but after two hours I would have thought it would have updated all. The time and date is fine and the clock is running but apart from the inside Rh and Temp which are local sensors,the only update is the ATM from the Rx
I have rebooted it to no avail. The frustration is that it was working perfectly before
Solved the issue a couple of pins on the Nano not soldered on both sides of the board - must have been intermittent
