Quote:I am trying to understand what my station is telling me so I have some questions
And it is trying to tell you some things...
Quote:If my RX station recieve LED flashes, that means that it has received data firm the Tx? (It does so quite regularly every 2 to 3 seconds)
In truth, it means that your RX unit is receiving data and is relaying it to the WD unit. If you disable the data relay function the LED will not blink despite the RX unit can be receiving data. So, if we have the data relay function enabled we can say that if the TX LED on the RX unit blinks we are receiving data from our TX units.
Quote:( it seems to transmit very randomly most times only once a minute)
First thing that your RX unit is trying to tell you: I'm with receptions problems!
Wind data is sent every 3 seconds (other data at different intervals), so if the LED on your RX unit isn't blink at least every 5 or 6 seconds your RF link is poor, and lots of data packets are being lost.
Quote:My WD obviously updates when the RX sends data but because it only updates infrequently it doesn't retain the previous data but shows blank lines (ie:no values )
could you please explain to me what should be happening?
Despite the WD unit be an optional part of the WeatherDuino Pro2 system, it is a very important part, with some interesting features, not always well known (certainly because I'm very bad on explaining some things)
Your WD unit is also trying to tell you that there are problems with the RF link, and that you are loosing lots of data packets.
I will try to explain:
The WD unit starts a timer every time is receives a type of data packet (there are several types). If the time since the last data packet of the same type is greater than a defined threshold, the display shows three dashes for the corresponding type of data.
If you see frequent dashes on your WD display, something is wrong with th RF signal. If the WD unit don't receive any type of data packet in a 5 minute interval, it will show you a big red display, alerting you about that.
Hope I have helped you, at least a little about how the system works.
Since the beginning that I have the feeling that almost all the issues reported by you are related with the RF signal. Focus your efforts in trying to get a reliable RF link.
As most as you can, avoid using any cable between the antenna SMA connector in the TX board and the antenna. Connect it directly to the SMA connector on the TX board, and leave some space around it free of metal parts.
If the use of a cable is absolutely necessary, make sure that its length is exactly a multiple of 1/4 the wave length of the TX frequency (~433.9Mhz)
Try to put the TX antenna in horizontal position, do the same in the RX unit, or try use (just on the RX unit) an antenna with a cable and try to find the best spot for reception (your metal roof certainly is not helping too).
