29-05-2014, 01:31
![[Image: WD_Pro2_logo02.png]](https://www.meteocercal.info/forum/images/01forum_img/WD_Pro2_logo02.png)
- Easy to build hardware
- Easy to find components
- Flexible and expandable
The WeatherDuino Pro2 emulates a Davis VP weather station and is fully compatible with Cumulus 1, CumulusMX or any other software that is compatible to a Davis Vantage Pro weather station.
The WeatherDuino Pro2 system is developed with flexibility in mind.
It can use a wide range of sensors and measuring instruments, making of it an universal system.
From low cost to high end weather instruments, you are free to decide, what instruments and brands you want to use, and the ones that most fit your requirements or budget.
Here is a list of the currently supported weather instruments.
Wind Speed sensors
--- Fine Offset Anemometers ---
Standard FO anemometers
FO anemometer modified with 1 hall effect sensor
--- Inspeed Anemometers ---
Inspeed Vortex, digital 8 pulse revolution
Inspeed Vortex, hall efect sensor
Inspeed Vortex, read switch sensor
--- Davis Anemometers ---
Davis 6410 and 7911 anemometers
--- Novalynx Anemometers ---
Novalynx, model 200-WS-02F
--- Environmental Measurements Limited ---
EML, model WSD1
--- Didcot Instrument Company ---
DIDCOT, model DWR205
--- Vector Instruments ---
Vector Instruments model A100LK
Vector Instruments model A100L2
Vector Instruments model A100R
Wind Direction Sensors
--- Fine Offset Wind Vane ---
Standard FO wind vane
--- Inspeed Wind Vane ---
Inspeed E-Vane 2
--- Davis Wind Vane ---
Davis 6410 and 7911 wind vane
DIDCOT, model DWD205
--- Virtually, any wind vane based in a potentiometer, or which have an analog output voltage (0 to 5V)
Tipping Bucket Rain Gauges
--- Wired Models ---
Fine Offset (PCE, Watson, etc)
Davis 7852
Texas Electronics, model 525
Virtually, any tipping bucket rain gauge
--- Wireless Models ---
Auriol H13726
Ventus W155
Hama EWS 1500
Meteoscan w155 w160
Alecto WS-3500
Balance RF-WS100
Temperature / Humidity Sensors
SHT35 from Sensirion
SHT31 from Sensirion
All SHT2x series from Sensirion
All SHT1x series from Sensirion
HTU21D
DHT21 or DHT22 (low end sensors)
Barometric Sensors
BMP085
BMP180
BMP280 (Pro2 PLUS only)
BME280 (Pro2 PLUS only)
UV Sensors
VEML6075
UVM-30A (requires WeatherDuino Solar/UV interface)
Solar Radiation
Apogee SP-110 Pyranometer (requires WeatherDuino Solar / UV interface)
WeatherDuino Solar Cell Pyranometer (requires WeatherDuino Solar / UV interface)
Soil Moisture / Temperature
Vegetronix VH400 / 1-Wire temperature sensor (requires WeatherDuino Soil / Leaf interface)
Leaf Wetness / Temperature
Decagon LWS / 1-Wire temperature sensor (requires WeatherDuino Soil / Leaf interface)
Air Quality Monitor (to be released August 2017)
Air Quality INDEX according to EPA standards
PM2.5 and PM10 readings
CO2
![[Image: WD_Pro2_overview.jpg]](https://www.meteocercal.info/forum/images/01forum_img/WD_Pro2_overview.jpg)
The minimal system consists of a TX and a RX unit, operating at a frequency of 433Mhz (315Mhz optionally).
Just one WeatherDuino Pro2 TX unit be enough to handle all the comums sensors of a weather station, however the system can handle up to three (four with the WeatherDuino Pro2 PLUS) TX units, allowing multi-positioning for the sensors. Ex: one TX unit for roof level sensors (wind speed and direction), another TX unit for ground level sensors (Temp / Hum, Rain).
TX Units are powered from any 12V power supply (consumption is around 100mA). The photo below shows an example of a TX Unit powered from solar energy.
![[Image: MTC_TX_Unit0.jpg]](https://www.meteocercal.info/forum/images/01forum_img/MTC_TX_Unit0.jpg)
At home, just one WeatherDuino Pro2 RX unit, receives all data and sends it to Cumulus or any other weather software which works with a Davis VP. (The WeatherDuino Pro2 PLUS system emulates a Davis Vantage Pro).
![[Image: WeatherDuinoPro2Plus_RX_v130_RevB_assembled.jpg]](https://www.meteocercal.info/forum/images/01forum_img/WeatherDuinoPro2Plus_RX_v130_RevB_assembled.jpg)
Image bellow is from CRASM weather station, running a WeatherDuino Pro2 PLUS and CumulusMX on a PI
![[Image: Pro2_PLUS_CRASM.jpg]](https://www.meteocercal.info/forum/images/01forum_img/Pro2_PLUS_CRASM.jpg)
![[Image: Pro2Plus_Overview_03.jpg]](https://www.meteocercal.info/forum/images/01forum_img/Pro2Plus_Overview_03.jpg)
The Wireless Display units are optional, but a very useful part of the system.
Watch your weather data, anywhere in the house. You can have as many as you wish.
![[Image: WeatherDuino_4Pro_WD_ESP8266_02_web.jpg]](https://www.meteocercal.info/forum/images/01forum_img/boards/WeatherDuino_4Pro_WD_ESP8266_02_web.jpg)
https://www.meteocercal.info/forum/video...8266_2.mp4
This video is from the an WiFi Wireless Display unit running an old software version. Current version its even more powerful.
This project in constant development, is in use at MeteoCercal since 2013, and by many other weather enthusiasts, a little all over the world. See the map here.
An WeatherDuino weather station is very easy to build, however building it its not like assembling an electronic kit, also it is not a kind of plug-and-play device. Definitely you will need some minimal knowledge of electronics, Arduino environment, and experience in welding of electronic parts.
Note: Info on this post may change from time to time, due to further developments and improvements.
![[Image: WeatherDuinoSystem.jpg]](https://www.meteocercal.info/forum/images/01forum_img/WeatherDuinoSystem.jpg)
