AuriolDuino within IoT
I'd like to use AuriolDuino to upload meterologic information to the Internet, as I already do with my home electricity consumption monitor (HECM).
The ideia would not be to connect it to a PC with specific SW, but instead to connect it to my internet router the same way I did with my HECM.
Check it out here
In order to do so, I'd need to know the communication stream format so I can process the information and decide what to send...
Is there any document that explains the communication stream format?
Any suggestion of an IoT site that can receive meteriological information?
Thanks in advance,
Jabss
(23-04-2015, 17:02)jabss Wrote:  In order to do so, I'd need to know the communication stream format so I can process the information and decide what to send...
The output follow the EasyweatherPlus format. You can find detailed info about it here:
http://www.jim-easterbrook.me.uk/weather/ew/
and here
http://wiki.sandaysoft.com/a/EasyWeather_Format
As the AuriolDuino system has been designed to be used with Cumulus, only the fields in bold are used (see last link).
