Threads: 31
Weather Station: Conder Weather, Canberra
Hi Moonlight,
According to that forum thread you've linked to, it sounds like the jury is still out as they are measuring 4.2v after the diode.
Personally I haven't noticed my RTC battery going "fat"
Welcome to the forum btw.
Moonlight, your question is pertinent!
I'm convinced that the ZS-042 module was designed to be used with a LIR2032 rechargeable battery. Curiously all ZA-042 modules that I received in the past, come with a LIR2032 battery. Currently, due to restrictions in the shipment by air mail, sellers usually send the modules without any battery, and people start to put CR2032 batteries on it.
I think that, more easy and safe than modify the RTC pcb, is separately buy a LIR2032 battery.
Threads: 5
The Arduino forum post referenced in post #1 above has had more replies since Werk_AG's response. One of the posts casts doubt on whether it is safe to use a LIR2032 with the ZS-042.
Has anyone here experienced problems using an LIR2032 and letting it charge on the ZS-042. Are people using the module with the charging circuit disabled?
