02-10-2026, 01:53
WeatherDuino - List of supported Weather Instruments
All the weather instruments listed below have been tested with the WeatherDuino system.
Wind Speed
Davis
Davis 6410, 7911 anemometers
Didcot Instrument Company
DIDCOT, model DWR205
Environmental Measurements Limited
EML, model WSD1
Fine Offset
Standard FO anemometers
FO anemometer modified with 1 Hall effect sensor
Honyuv
HY-WDC series, Ultrasonic - Using MODBUS (Requires WeatherDuino AGRO Transmitter) 1
Inspeed
Inspeed Vortex, digital 8 pulse revolution
Inspeed Vortex, Hall effect sensor
Inspeed Vortex, read switch sensor
Lufft
Ventus X-UMB Ultrasonic - Using MODBUS (Requires WeatherDuino AGRO Transmitter) 1
Ventus 200A-UMB Ultrasonic - Using MODBUS (Requires WeatherDuino AGRO Transmitter) 1
Novalynx
Novalynx, model 200-WS-02F
Vector Instruments
Vector Instruments model A100LK
Vector Instruments model A100L2
Vector Instruments model A100R
Virtually any 0 to 5V pulse anemometer may be used provided their specifications are known.
Wind Direction
Davis
Davis 6410 and 7911 wind vane
DIDCOT, model DWD205
Model WSD1
Fine Offset
Standard FO wind vane
Honyuv
Inspeed
Inspeed E-Vane 2
Novalynx
Model 200-WS-02F
Virtually any analogue Wind Vane with output from 0 to 5V
Rain Gauges
Wired Models
Fine Offset (PCE, Watson, etc)
Davis 7852
Texas Electronics, model 525
Hunan Rika Electronic Technology, model RK400-01
Virtually, any tipping bucket rain gauge can be used, resolution can be set in the software.
Wireless Models
Auriol H13726
Ventus W155
Hama EWS 1500
Meteoscan w155 w160
Alecto WS-3500
Balance RF-WS100
Outdoor Temperature / Humidity Sensors
SHT31 from Sensirion
All SHT2x series from Sensirion
All SHT1x series from Sensirion
SHT75 from Sensirion
HTU21D, DHT21 or DHT22 (low-end sensors) - Support for these sensors is now deprecated
Solar Radiation / PAR Sensors
(Old Pro2 TX systems will require the Solar Radiation / UV interface)
Apogee SP-110, Pyranometer (May require Solar / UV interface)
Apogee SQ-110, Sun Calibration Quantum Sensor (experimental)
WeatherDuino Solar Cell Pyranometer
McVan Instruments MIDDLETON SP440
UV Index Sensors
UVM-30A
VEML6075
Hunan Rika Electronic Technology, model RK200-07 - Using MODBUS (Requires WeatherDuino AGRO Transmitter) 1
DFRobot RS485 UV Sensor - Using MODBUS (Requires WeatherDuino AGRO Transmitter) 1
Soil Sensors
(Requires the Soil / Leaf interface)
Vegetronix VH400, Soil Moisture Sensor
Dallas DS18B20, Temperature sensor
Dallas DS18S20, Temperature sensor
Leaf Sensors
Decagon LWS, Leaf Wetness Sensor (current name is METER PHYTOS 31)
Air Quality Sensors
(Requires Air Quality Monitor hardware]
Dust Sensors
Sensirion SPS30
Plantower PMS7003
Nova SDS011
CO2 Sensors
Sensirion SDC30
MH-Z19
1 - The WeatherDuino 4Pro AGRO Transmitter isn't currently available!
Wind Speed
Davis
EML, model WSD1
Fine Offset
Honyuv
Inspeed
Lufft
Novalynx
Vector Instruments
Wind Direction
Davis
Model WSD1
Fine Offset
Honyuv
Inspeed
Inspeed E-Vane 2
Novalynx
Model 200-WS-02F
Rain Gauges
Wired Models
Davis 7852
Wireless Models
Auriol H13726
Ventus W155
Hama EWS 1500
Meteoscan w155 w160
Alecto WS-3500
Balance RF-WS100
UV Index Sensors
UVM-30A
VEML6075
Soil Sensors
Leaf Sensors
Air Quality Sensors
Dust Sensors
Sensirion SPS30
Plantower PMS7003
Nova SDS011
CO2 Sensors
Sensirion SDC30
MH-Z19
