08-02-2024, 01:18
I had the wifi on my RX unit working, at least it connected to my wifi, and I could see it on the router/wireless network connected devices list.
It did however showed on the display that it was connecting every 5 minutes or so (don't know if that's normal?). There was also a green dot on the display.
Now I had it connected to the 'Guest' account on my wifi, which meant it was not visible to my laptop. The Guest account issues a different group of IP addresses: 192.168.101.xx vs 192.168.100.xx for the 'normal' connections.
To fix this I changed the wifi credentials in the software to my 'normal' network. I copied and pasted both the SSID and the password from the router webpage, to avoid typos.
Compiled and uploaded all ok.
However the RX unit now fails to connect, and of course doesn't show up in the connected devices list.
Encryption is set to the same scheme on both the Guest and normal wifi. The router does have both 2.4 GHz and 5 GHz wifi, with different SSID's, I tried both but no differences.
I do have all the on-line options for the several weather data sites on in the software, but have no accounts there yet. But I can't see that having any influence on the problem.
Could there be a reset or something like that needs to be done? I tried the reset button on the RX board, but no change.
Thanks for any tips or suggestions.
Gerard
Gerard
