Threads: 336
Country:
Hi SR123
As you referred, sometimes after a software upgrade it is also needed to I uploaded the icons and fonts package (data folder) again.
Thanks for reporting as solved.
Rgs,
Threads: 5
Country:
Good evening everyone. I updated the receiver with the new firmware b006. I'm having the same problem: the fonts weren't loaded correctly. I don't remember how to reload them. Should I copy and paste the data folder from the previous view to the new one and then recompile everything? Thanks for clarifying.
Threads: 336
Country:
There is no need to recompile the code, just upload the data folder using Arduino IDE:
Tools -> ESP32 Sketch Data Upload
Threads: 5
Country:
Hi everyone.
I tried to upload the icon pack as described.
It didn't work. I can access the graphs, but the graphical part of the weather forecast icons and the scaling of some text characters don't load. When I follow the procedure described by werk_ag, the sketch loads without errors. At this point, I don't want say which the ESP32 I purchased is completely incompatible with the original due to an accidental drop. Board purchased: AZDelivery ESP32 D1 Mini NodeMCU WiFi Module ESP 32 Bluetooth USB-C Arduino compatible and Wemos D1 Mini with e-book. Any feedback is welcome. Thanks.
Threads: 336
Country:
What haven't work? The upload of the data packet (fonts and icons) haven't completed?
Please check in Arduino IDE if the option "Erase all flash before sketch upload" is disabled, otherwise everytime you upload the firmware the fonts and icons will be deleted.
Threads: 5
Country:
I tried several times to follow the instructions but nothing, it doesn't work. The upload process completes without errors and the receiver updates but in the end nothing changes.
