RF problems
I have built both modules and have managed at last to programme the Rx, Rx is working with regards to getting and seeing internal heat, humidity and atmospheric readings. I have powered up the TX module, after I thought I had programmed the Tx, the transmit led is flashing on regular basis, but I am not getting any readings on the screen in the Rx. Is the flashing LED a definite sign that there is transmission ? How can I check to see if there are any actual transmissions and if they are being received ?
Are there any components that can be checked in case they have been fried ?
regards
tyntop
Could you copy/paste your current config options for the RX and TX unit?
Do you have any sensor connected to the TX unit?
A picture of the TX unit could also help.
Hi, please find both ino files below as loaded onto the nano's.
regards
tyntop
//-------------------------------------------------------------------------------------- // WeatherDuino Pro2 RF Transmiter // Compatible with Cumulus Weather Software // Boards compatibility   : WeatherDuino TX v2.xx, Board Series   // Software compatibility : WeatherDuino RX v013 series only // // Version: 0.13-b005 // Version Released date: 13/01/2015 // Last revision date   : 10/01/2015 // Licence: GNU GPL // Author : Werk_AG (Portugal) // // I wish to thanks to kevinkessler from http://kesslerarduino.wordpress.com/ // for the base code to read wind and rain sensors. //-------------------------------------------------------------------------------------- #include <VirtualWire.h> // library for RF RX/TX #include <Wire.h> #include <SHT1x.h> #include <SHT2x.h> #include "HTU21D.h" // library for HTU21 Temp/Hum Sensor #include <DHTxx.h>            // library for DHTxx #include <Timer.h> #include "RunningAverage.h" #include <EEPROM.h> // Library to eeprom read and write // -------------------------------------------------------------------------------------- //   User configurable options start here.  // -------------------------------------------------------------------------------------- byte StationID = 0xA1; // Must be equal to your RX Unit (Value from 0x00 to 0xFF) byte UnitID = 0; // If you use only one TX unit define it as UnitID = 0                                 // For a second TX unit, define it as UnitID = 1 // -------  Let's define the data we want to send -------------- //#define ID0 0        // Temp / Hum sensors - 0 for SHT2x sensor, 1 for HTU21 sensor #define ID1 0        // Temp / Hum sensors - 0 for SHT1x sensor, 1 for DHT22 sensor #define ID2          // Wind data #define ID3          // Rain data //#define ID4          // UV / SolRad data #define ID5          // Hardware Status - System Temp, Battery Voltage etc byte fanOn_HiTemp = 32; // RS Fan turn on when outside temperature is >= than this value (ºC) byte fanOn_LowTemp = 3; // RS Fan turn on when outside temperature is <= than this value (ºC) byte fanOn_LowWind = 2; // RS Fan turn on when Wind Average is <= than this value (m/s) // --------------------------------------------------------------------------------------------------- //                       There is nothing to edit below this line !!! // --------------------------------------------------------------------------------------------------- //#define DebugID0 //#define DebugID1 //#define DebugID2 //#define DebugID3 //#define DebugID4 //#define DebugID5 //#define Local_TestMode #if ID0 == 1 HTU21D myHTU21; #endif #if ID1 == 0 // Specify data and clock connections and instantiate SHT1x object #define dataPin  6 #define clockPin 9 SHT1x sht1x(dataPin, clockPin); #endif #if ID1 == 1 // DTH22 Data wire is plugged into port 6 on the Arduino // Connect a 10K resistor between VCC and the data pin (strong pullup) #define DHT22_PIN 6 DHTxx dht (DHT22_PIN); #endif // --- Analog Pins --- #define SolarRad_PIN A0 #define IndiceUV_PIN A1 #define BatVolt_PIN A2 #define VANE_PIN A3 #define SysTemp_PIN A7 // --- Digital Pins --- #define RAIN_GAUGE_INT 0 #define ANEMOMETER_INT 1 #define RAIN_GAUGE_PIN 2 #define ANEMOMETER_PIN 3 #define VANE_PWR 4 #define Fan_PIN 5 #define TXPower_PIN 7 #define TX_PIN 8             // Transmitter connected to pin 8 // --- Wind ------------ #define WIND_FACTOR 0.666667          // Factor 2.4 Km/h = 0,66666666666667 M/s #define TEST_PAUSE 30                 // Value for WindAverage - 30 secs volatile unsigned long anem_count = 0; volatile unsigned long anem_last = 0; volatile unsigned long anem_min = 0xffffffff; unsigned int WindAvg, WindGust; unsigned int last_WindGust = 50000; RunningAverage raWindAvg(10); // --- Vane ----------- const int vaneValues[] PROGMEM={66,84,92,127,184,244,287,406,461,600,631,702,786,827,889,946}; const int vaneDirections[] PROGMEM={1125,675,900,1575,1350,2025,1800,225,450,2475,2250,3375,0,2925,3150,2700}; #ifdef Local_TestMode const char vaneDirectionsText[16] [4] = {"N","NNE","NE","ENE","E","ESE","SE","SSE","S","SSW","SW","WSW","W","WNW","NW","NNW"}; String winddr; #endif unsigned int WindDir; // --- Rain ----------- //#define RAIN_FACTOR 0.3                           // Datasheet value = 0.2794 const float RAIN_FACTOR = 0.3; // Datasheet value = 0.2794 volatile unsigned long rain_count = 0; volatile unsigned long rain_last = 0; volatile unsigned long RainFall_rate; unsigned int TotalRainTips; unsigned int LastHourRainTips; unsigned int lasthour_TotalRainTips = 0; unsigned int last_TotalRainTips = 0; //float TotalRain; byte Pool_Rain_Interval = 31; //Pool Rain tick counter every 31 seconds byte TotalRainTips_Eeprom_adr = 10; // --------------------- RunningAverage raSolarRad(4); RunningAverage raIndiceUV(4); char DataPacket[32]; byte PacketID; byte RSfan; unsigned int avg_SolarRad, SolarRad, avg_IndiceUV; float IndiceUV; float TotalRain; // Used only in Debug Mode unsigned int BatVolt, SysTempADC; int ID0_TemperaturaExt, ID1_TemperaturaExt; int ID0_HumidadeExt, ID1_HumidadeExt; #ifdef Local_TestMode // ----------   Temp Var for debug --------------------- int DHT_HumidadeInt = 500; int DHT_TemperaturaInt = 200; int DHT_TemperaturaInt_offset = 0.0; float pressure = 100000; float pressure_offset = 0.0; //------------------------------------------------ #endif Timer t; // --------- Soft Reset ------------------------------------------- void(*softReset)(void) = 0; //SoftwareReset vector (goto address 0) // SETUP //-------------------------------------------------------------------------------------- void setup() {  //  erase_eeprom();    //------------------------------------------------------------ // Setup the transmitter //------------------------------------------------------------   vw_set_ptt_pin(TXPower_PIN);   vw_set_tx_pin(TX_PIN);        // Transmitter connected to pin 8   vw_setup(1000);         // Bits per second //------------------------------------------------------------   pinMode(13,OUTPUT);   digitalWrite(13, LOW);   pinMode(Fan_PIN,OUTPUT);   pinMode(TXPower_PIN,OUTPUT);   Wire.begin();   #if ID0 == 1   myHTU21.begin();   #endif     #ifdef Local_TestMode     Serial.begin(19200);     t.every(3050, Cumulus_Output);   #endif   #ifdef ID0   t.every(19000, send_SensorID0);   #endif   #ifdef ID1   t.every(53000, send_SensorID1);   #endif   #ifdef ID2     setupWindInts();   t.every(5000, send_SensorID2); // Send PacketID2. Before sending, call getGust() function   t.every(TEST_PAUSE * 1000, getUnitWind); // Calls Wind Average function +- every TEST_PAUSE seconds   #endif   #ifdef ID3   setupRainInts();   TotalRainTips = eepromReadInt(TotalRainTips_Eeprom_adr);   t.every(Pool_Rain_Interval * 1000, send_SensorID3);   t.every(3600000, TotalRainTips_toEeprom); // Every 1 hours call routine to save Rain Totals to eeprom (Routine only save if value is different from last call)   #endif   #ifdef ID4   t.every(37000, send_SensorID4);   //t.every(5000, send_SensorID4); // For testing...   #endif      #ifdef ID5   t.every(97000, send_SensorID5);   #endif } // MAIN LOOP //-------------------------------------------------------------------------------------- void loop() {       // Reboot if millis is close to rollover. RTC_Millis won't work properly if millis rolls over. Takes 49 days to rollover   if( millis() > 4294000000UL ) softReset();   t.update(); }   // End MAIN LOOP ------------------------------------------------------------------------
/***************************************************************************  WeatherDuino Pro2 RF Receiver  Compatible with Cumulus Weather Software  RX Boards compatibility: WeatherDuino RX Boards Series v2.xx, 3.xx and v4.xx    Software compatibility : WeatherDuino TX v013 series only  Version: 0.13-b014     : NEEDS Arduino 1.5.7 or newer to compilie  Version Release date   : xx/xx/2015  Last revision date     : 14/01/2015  Ver start dev date     : 03/10/2014  Licence                : GNU GPL  Author                 : Werk_AG (Portugal)  Weather Station Website: http://www.meteocercal.info  Support Forum          : http://www.meteocercal.info/forum/Forum-WeatherDuino-Pro2  There is no manual. Look at the code, almost anything important is commented.  User configurable options are on first lines of code, just after include statements.    **************************************************************************************/ /* // BOF preprocessor bug prevent - insert me on top of your arduino-code #if 1 __asm volatile ("nop"); #endif */ #include <SPI.h> #include <VirtualWire.h> // library for RF RX/TX #include <Wire.h> // needed for BMP085, RTC, LCD #include <RTC_DS3231.h>           // From https://github.com/mizraith/RTClib #include <DHTxx.h>                // library for DHTxx #include <BMP085.h> #include <LiquidCrystal_I2C.h> // Library for LCD #include <EEPROM.h> // Library to eeprom read and write #include <ClickButton.h> // Button Library #include <AC_GFX.h> #include <AC_ST7735.h>            // TFT Hardware-specific library #include <SerialCommand.h> #include "VP2crc.h" #include "data_structs.h" #include "Davisdef.h" // -------------------------------------------------------------------------------------- //   User configurable options start here.  // -------------------------------------------------------------------------------------- // --- Station ID, use the same value in your TX unit const byte StationID = 0xA1; // --- Define Software Operation Mode #define Work_Mode        0   // Mode 0= Davis VP2 Emulation Mode, Mode 1= EasyWeather Mode // --- Define your Display type #define DisplayType      0   // 0= TFT, 1= LCD 20x4, 2= LCD 16x2 // --- Define Backlight timeOut // --- With RX boards version <= 3.01 without the TFT backlight control mod, always set this value to 0 byte BackLight_Timeout = 0; // Timeout for TFT backlight in minutes (1 to 255). 0 = Always ON // --- Define Temperature and Wind Display units byte Temp_Display_Unit = 0; // 0 for ºC, 1 for ºF byte Wind_Display_Unit = 1; // 0 for Km/h, 1 for mph, 2 for m/s // --- Fine adjusts for Inside Temperature and Barometer const int TemperaturaInt_offset = 0; // Inside Temperature Fine Adjust in Tenths of Degree (-4 = -0,4ºC) const float pressure_offset = -1.0; // Pressure Fine Adjust in mB // --- Some Data from your Weather Station location #define LATITUDE        518    // Put here your Station latitude in tenths of degrees North #define LONGITUDE       -33    // Put here your Station longitude in tenths of degrees East #define ELEVATION       62    // Put here your Station height above sea level in Meters // --- Define Starting Hour of your Meteorological Day #define MeteoDay_HStart 1    // Use values from 0 to 23 // --- Define Wind Speed and Wind Gust resolution #define VP2_WindRes     2    // If set to 2, set Cumulus Wind Speed and Wind Gust multipliers to 0.448. Wind Resolution 0.72 Km/h                              // If set to 1, set Cumulus Wind Speed and Wind Gust multipliers to 0.224. Wind Resolution 0.36 Km/h                              // WARNING !!! Setting this variable to 1 allows a better wind speed and gust resolution,                              // but also limits both of them, to a maximum reading of just 91.8 Km/h                              // This setting only have effect when the software is used in Davis VP2 emulation mode     // --- Define type of outside temperature / humidity sensor #define TH_OutSensor     1    // 0 for SHT21 or HTU21D sensor, 1 for SHT1x or DHT22 sensor, // ---- Let's define the source of the sensors we want to receive // ---- If you have all the sensors connected to only one TX board, always select Unit 0 #define TH_OutUnit       0    // 0 for Temp/Hum sensor connected to TX_Unit 0, 1 for Temp/Hum sensor connected to TX_Unit 1 #define WIND_OutUnit     0    // 0 for Wind instruments connected to TX_Unit 0, 1 for TX_Unit 1, 2 for Auriol RF Odometer #define RAIN_OutUnit     0    // 0 for Rain Gauge connected to TX_Unit 0, 1 for TX_Unit 1, 2 for Auriol RF Rain Gauge #define SRUV_OutUnit     0    // 0 for Solar Rad / UV sensors connected to TX_Unit 0, 1 for TX_Unit1 // --------------------------------------------------------------------------------------------------- //                       There is nothing to edit below this line !!! // --------------------------------------------------------------------------------------------------- String Software_Ver = "v0.13-b014"; // ------ Define hardware PINS ---------------------------------------------------------- #define Led1_PIN         2 #define BackLight_PIN    3 #define RX_PIN           8 #define DHT22_PIN        9 #define Button1_PIN      5 #define TX_PIN          14     // A0 #define TX_Power_PIN    15     // A1 // ------------------------------------------------------------------------------------- #define BMP085_ADDRESS 0x77    // I2C address of BMP085 #if Work_Mode == 0 //#define TIME_ZONE_INDEX       #define DST_MANAUTO          1 #define DST_OFFON            0 //#define GMT_OFFSET_LSB //#define GMT_OFFSET_MSB #define GMT_OR_ZONE          0 #define UNIT_BITS            0x3E  // BAROMETER_UNITS_HPA | TEMP_UNITS_TENTHS_C | ELEVATION_UNITS_M | RAIN_UNITS_MM | WIND_UNITS_MPH #define SETUP_BITS           0x51  // LONGITUDE_WEST | LATITUDE_NORTH | RAIN_COLLECTOR_02MM | WIND_CUP_LARGE | MONTH_DAY_MONTHDAY | AMPM_TIME_MODE_24H #define RAIN_YEAR_START      1     // 1 = Jan #define ARCHIVE_PERIOD      15 #define DAVIS_PACKET_LEN     8     // ISS has fixed packet lengths of eight bytes, including CRC #define LOOP_PACKET_LENGTH  97 #define LOOP_INTERVAL     2500 unsigned long lastLoopTime = 0; unsigned int loopCount = 0; #endif #if DisplayType == 0 //#define TFT_SCLK 13 //#define TFT_MOSI 11 //#define TFT_CS  10                                      // Chip select line for TFT display //#define TFT_DC   6                                      // Data/command line for TFT //#define TFT_RST  7                                      // Reset line for TFT (or connect to +5V) //AC_ST7735 tft = AC_ST7735(TFT_CS, TFT_DC, TFT_RST);     // Hardware SPI Mode AC_ST7735 tft = AC_ST7735(10, 6, 7);                      // Hardware SPI Mode byte TFT_mode = 1; #endif #if DisplayType >= 1 // set the LCD address to 0x27 for a 20 chars 4 line display // Set the pins on the I2C chip used for LCD connections: //                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address byte lcd_L_info = 1; //boolean LCD_flip = true; // make one custom character: byte heart[8] = {   0b00000,   0b01010,   0b11111,   0b11111,   0b11111,   0b01110,   0b00100,   0b00000 }; #endif // Important for Auriol data receiving - NEVER TOUCH THIS --------- #if (WIND_OutUnit == 2 || RAIN_OutUnit == 2) #define   nobits 36 #define   smin   7500 #define   smax   9900 #define   semin  250 #define   semax  750 #define   lmin   1700 #define   lmax   2300 #define   hmin   3700 #define   hmax   4300 #endif // --------------------------------------------------------------- // the Button ClickButton button1(Button1_PIN, LOW, CLICKBTN_PULLUP); const char vaneDirectionsText[16] [4] = {"N","NNE","NE","ENE","E","ESE","SE","SSE","S","SSW","SW","WSW","W","WNW","NW","NNW"}; char RX_DataPacket[32]; char TX_DataPacket[32];    const float UnitTip_value[3] = {0.3, 0.3, 0.25}; float pressure; float rainf; //float RainToday; float averagew_ms, gust_ms; float Output_WSpeed, Output_WGust, Output_RToday; float Output_UV; unsigned long last_millis_0; unsigned long StartTime, BackLight_Timer; int ButtonFunction = 0; // Arbitrary Button function int TemperaturaInt; int Output_T_Int, Output_T_Out; unsigned int Output_H_Int, Output_H_Out; unsigned int Output_SRad; unsigned int windd; unsigned int last10min_TotalRain_tips; unsigned int RainToday_tips; unsigned int DaysWithoutRain; unsigned int YearNow_Eeprom; const byte Display_Units = (Temp_Display_Unit << 4) | Wind_Display_Unit; const byte TotalRain_tips_Eeprom_adr = 50 + (RAIN_OutUnit * 10); const byte RainDayBegin_tips_Eeprom_adr = 80 + (RAIN_OutUnit * 10); const byte RainYearBegin_tips_Eeprom_adr = 110 + (RAIN_OutUnit * 10); const byte thisYearRain_tips_Eeprom_adr = 140 + (RAIN_OutUnit * 10); const byte DayNow_Eeprom_adr = 170; const byte YearNow_Eeprom_adr = 180; const byte DaysWithoutRain_Eeprom_adr = 190; const byte FirstRunCheck_Eeprom_adr = 200; byte FirstRunCheck; byte DayNow_Eeprom; byte RSfan; byte last_min = 99; byte last_min1 = 99; byte last_second0 = 99; byte last_second1 = 99; boolean StartUp = true; boolean sysinfo = false; boolean init_SysInfoTFT = true; boolean BackLight_State = true; boolean validPacket; String code; // ------ Create objects --------------- RTC_DS3231 RTC; DHTxx dht (DHT22_PIN); BMP085 bmp; DavisCRC davis; SerialCommand sCmd; LoopPacket loopData; // ------ Setup ---------------- void setup() {   Serial.begin(19200);   // --- If Auriol Wind is selected in VP2 mode, auto-disable data relay (because short memory) -------   #if (Work_Mode == 0 && WIND_OutUnit == 2)     #define TX_relay 0   #else     #define TX_relay 1   #endif   //--------------------------------------------------------- //     Receiver setup //---------------------------------------------------------     vw_set_rx_pin(RX_PIN);    vw_setup(1000);           // Bits per sec    vw_rx_start();                 // Start    pinMode(RX_PIN, INPUT);    //#ifdef RainAuriol    // digitalWrite(receiver_PIN, HIGH); // Activa internal pull up resistor    //#endif //------------------------------------------------------------ //      Transmiter Setup //------------------------------------------------------------ #if TX_relay == 1     pinMode(TX_Power_PIN, OUTPUT);     pinMode(TX_PIN, OUTPUT);     vw_set_ptt_pin(TX_Power_PIN);     vw_set_tx_pin(TX_PIN);                       // Transmitter connected to pin A0 #endif //------------------------------------------------------------   pinMode(Led1_PIN, OUTPUT);   //pinMode(Button1_PIN,INPUT);   //digitalWrite(Button1_PIN, HIGH); // Activa internal pull up resistor - Also done in Button library   pinMode(BackLight_PIN, OUTPUT);   digitalWrite(BackLight_PIN, HIGH); // Turns ON TFT/LCD backlight   Wire.begin();   bmp.begin();   RTC.begin(); // Set RTC to compile time /*   DateTime now = RTC.now();   DateTime compiled = DateTime(__DATE__, __TIME__);   if (now.unixtime() != compiled.unixtime()) {     //Serial.println("RTC is older than compile time!  Updating");     RTC.adjust(DateTime(__DATE__, __TIME__));   } */ #if DisplayType == 0   #define ST7735_DARKGRAY        0x5ACB      // Box Backgound   #define ST7735_LIGHTGRAY       0xB5B6      // Box Contour   #define ST7735_SKYBLUE         0x7D5F   #define ST7735_NICEGREEN       0x0551   #define ST7735_LORANGE         0xFCA0   #define ST7735_VIOLET          0xB01C      tft.initR(INITR_BLACKTAB);             // initialize a ST7735R chip, Black Tab   // tft.setRotation(0); // 0 (0 degrees), 1 (90 degrees), 2 (180 degrees) and 3 (270 degrees)   // tft.invertDisplay(false);   tft.setTextWrap(false);   init_TFT_M1(); #endif #if DisplayType == 1   init_LCD20x4(); #endif #if DisplayType == 2   init_LCD16x2(); #endif #if Work_Mode == 0   // Initialize the loop data array   memcpy(&loopData, &loopInit, sizeof(loopInit));   //Setup callbacks for SerialCommand commands   sCmd.addCommand("LOOP", cmdLoop); // Send the loop data   sCmd.addCommand("NVER", cmdNver); // Send the version string   sCmd.addCommand("TEST", cmdTest); // Echo's "TEST"   sCmd.addCommand("VER", cmdVer); // Send the associated date for this version   sCmd.addCommand("WRD\x12M", cmdWRD); // Support the Davis legacy "WRD" command   //sCmd.addCommand("GETTIME", cmdGettime); // Send back current RTC date/time   sCmd.addCommand("SETTIME", cmdSettime); // Update current RTC date/time from PC   sCmd.addCommand("EEBRD", cmdEebrd); // EEPROM Read   sCmd.setDefaultHandler(cmdUnrecognized);    // Handler for command that isn't matched   sCmd.setNullHandler(cmdWake);               // Handler for an empty line to wake the simulated console   //sCmd.addCommand("BARDATA", cmdBardata); // Barometer calibration data   //sCmd.addCommand("DMPAFT", cmdDmpaft); // Download archive records after date:time specified   //erase_eeprom();   EEPROM.write(EEPROM_LATITUDE_LSB, LATITUDE & 0xFF);   EEPROM.write(EEPROM_LATITUDE_MSB, LATITUDE >> 8);   EEPROM.write(EEPROM_LONGITUDE_LSB, LONGITUDE & 0xFF);   EEPROM.write(EEPROM_LONGITUDE_MSB, LONGITUDE >> 8);   EEPROM.write(EEPROM_ELEVATION_LSB, ELEVATION & 0xFF);   EEPROM.write(EEPROM_ELEVATION_MSB, ELEVATION >> 8);   //EEPROM.write(EEPROM_TIME_ZONE_INDEX, TIME_ZONE_INDEX);   EEPROM.write(EEPROM_DST_MANAUTO, DST_MANAUTO);   EEPROM.write(EEPROM_DST_OFFON, DST_OFFON);   //EEPROM.write(EEPROM_GMT_OFFSET_LSB, GMT_OFFSET_LSB);   //EEPROM.write(EEPROM_GMT_OFFSET_MSB, GMT_OFFSET_MSB);   EEPROM.write(EEPROM_GMT_OR_ZONE, GMT_OR_ZONE);   EEPROM.write(EEPROM_UNIT_BITS, UNIT_BITS);   EEPROM.write(EEPROM_SETUP_BITS, SETUP_BITS);   EEPROM.write(EEPROM_RAIN_YEAR_START, RAIN_YEAR_START);   //EEPROM.write(EEPROM_ARCHIVE_PERIOD, ARCHIVE_PERIOD); #endif   //EEPROM.write(DayNow_Eeprom_adr,0);   //eepromWriteInt(YearNow_Eeprom_adr, 0);   //eepromWriteInt(RainDayBegin_tips_Eeprom_adr, 0);   //eepromWriteInt(RainYearBegin_tips_Eeprom_adr, 0);   //eepromWriteInt(thisYearRain_tips_Eeprom_adr, 0);   //eepromWriteInt(TotalRain_tips_Eeprom_adr, 0);   //eepromWriteInt(DaysWithoutRain_Eeprom_adr, 1);   //EEPROM.write(FirstRunCheck_Eeprom_adr, 0);   Unit[RAIN_OutUnit].RainDayBegin_tips   = eepromReadInt(RainDayBegin_tips_Eeprom_adr);   Unit[RAIN_OutUnit].RainYearBegin_tips  = eepromReadInt(RainYearBegin_tips_Eeprom_adr);   Unit[RAIN_OutUnit].TotalRain_tips      = eepromReadInt(TotalRain_tips_Eeprom_adr);   DaysWithoutRain                        = eepromReadInt(DaysWithoutRain_Eeprom_adr);   YearNow_Eeprom                         = eepromReadInt(YearNow_Eeprom_adr);   DayNow_Eeprom                          = EEPROM.read(DayNow_Eeprom_adr);   FirstRunCheck                          = EEPROM.read(FirstRunCheck_Eeprom_adr);   StartTime = millis();   BackLight_Timer = StartTime; /*   Serial.println(EEPROM.read(FirstRunCheck_Eeprom_adr));   Serial.println(EEPROM.read(DayNow_Eeprom_adr));   Serial.println(eepromReadInt(YearNow_Eeprom_adr));   Serial.println(eepromReadInt(RainDayBegin_tips_Eeprom_adr));    Serial.println(eepromReadInt(RainYearBegin_tips_Eeprom_adr));   Serial.println(eepromReadInt(thisYearRain_tips_Eeprom_adr));   Serial.println(eepromReadInt(TotalRain_tips_Eeprom_adr));   Serial.println(eepromReadInt(DaysWithoutRain_Eeprom_adr)); */ } // --------- End Setup ---------------- void loop() {    DateTime now = RTC.now();      if (millis() - StartTime > 120000)    {      Rain_updates(now.year(), now.month(), now.day(), now.hour(), now.minute());      StartUp = false;    }    if (vw_have_message()) ReceiveDataRF();        #if RAIN_OutUnit == 2     Auriol_Rain();   #endif   #if WIND_OutUnit == 2     Auriol_Wind();   #endif // -- Davis VP2 Mode   #if Work_Mode == 0   if (!StartUp) // Prevents Cumulus connection before 2 minutes after a restart.    {      if (Serial.available() > 0) loopCount = 0; // if we receive anything while sending LOOP packets, stop the stream      sendLoopPacket();                          // send out a LOOP packet if needed      sCmd.readSerial();                         // Process serial commands    }    #endif // -- EasyWeather Mode - Output every 10 Sec   #if Work_Mode == 1   if (now.second() % 10 == 0 && now.second() != last_second0)   {     easyweather_Output();     last_second0 = now.second();       }     #endif   #if TX_relay == 1   // ---------------------- Broadcast Time every 15 Minutes -------------------------     if (now.minute() % 15 == 0 && now.second() == 0)       {         int Master_Time = now.hour() << 8 | now.minute();         sendData(StationID, 80, now.year() - 1900, now.month() , now.day(), Master_Time);       }     #endif        // --- Read local sensors every minute   if (now.minute() % 1 == 0 && now.minute() != last_min1)   {    read_BMP();    read_DHT();    last_min1 = now.minute();      //Update_Display(); // HERE JUST FOR TESTING   }     if (BackLight_Timeout != 0 && (millis() - BackLight_Timer) > BackLight_Timeout * 60000)    {      BackLight_State = false;      digitalWrite(BackLight_PIN, BackLight_State);    }    // -- Update seconds on TFT Clock   #if DisplayType == 0   if ((BackLight_State == true) && (sysinfo == false) && (now.second() != last_second1)) // Clock update interval - 1s    {        DisplayClock_TFT(now.year(), now.month(), now.day(), now.hour(), now.minute(), now.second());      last_second1 = now.second();    }    #endif      // Update button state   button1.Update();   // Save click codes in ButtonFunction, as click codes are reset at next Update()   if (button1.clicks != 0) ButtonFunction = button1.clicks;   if(button1.clicks == 1) B_click();   if(ButtonFunction == 2) B_doubleclick();   #if DisplayType == 0   if(ButtonFunction == -1) B_LongPress();   #endif } // End void loop
(20-02-2015, 06:13)Werk_AG Wrote:  Could you copy/paste your current config options for the RX and TX unit?
Hi.
all the sensors were connected to the TX unit.
regards
tyntop
I don't see anything wrong in your user config options. Except a less usual value for the Starting Hour of your Meteorological Day, but this doesn't matter for your problem.
As I said some pics of your boards may help...
Is you TX board powered from 12V or only by the USB (a common error when testing)?
Have you added an antenna to the TX module?
[Image: FS1000A_Antenna.jpg]
[Image: WD_RF_Ant.jpg]
What you mean with "all the sensors were connected to the TX unit"?
Can you specify what sensors are you using?
Both RX and TX code includes some debug functionalities, but using them requires some knowledge about Arduino programing.
Surely I can help you, but I need more specific details, otherwise I'm just trying to guess.
Hi, sensors attached to my system are outside temp is a sht10, windspeed and wind direction and rain are wh1080. power supply 12v, and antenna fitted as pictures above.
I did take pictures of TX but the files are bigger than the upload limits allowed on this site, unless i can email them to you.
regards
tyntop.
Ok, so let's see if the TX unit is reading the sensors...
On the TX software, go to line 56 (//#define Local_TestMode) and uncomment it. Compile and upload to Arduino TX unit.
After upload, open the Serial Monitor (Tools -> Serial Monitor)
Some lines of data will appear soon. Let it run for some minutes.
Please copy/paste those lines here.
Thank you
Hi, I will do as you ask, what do you mean by uncomment, an example would be handy please, ie a line before and after uncommenting i will then do as you ask tomorrow if thats ok I am not able to do it tonite.
regards
tyntop.
Uncommenting a line means remove the double slash at the beginning of the line.
EX:
//#define Local_TestMode -> This line is a comment, its content will not be processed by the compiler
#define Local_TestMode -> This line is not a comment, its content will be processed by the compiler
Hi here is my tx test as you asked for hop this will suffice as I was not able to copy and paste from arduino.
regards
tyntop
Hi, one more point that I think I should make you aware of is that the voltage regulator does not get hot anymore as it used to, when the power supply is connected, could that be a sign that it is not working anymore ? the TX led still flashes though.
regards
tyntop.
Hi, sorry just noted something else, I uploaded the normal sketch after reversing the test mode and the TX light on the nano is not blinking like it was in test mode does that tell you anything ?
regards
tyntop.
Quote:Hi here is my tx test as you asked for hop this will suffice as I was not able to copy and paste from arduino.
That file it's only garbage, it's useless.. When you open the serial monitor window, you must select the same baudrate (bottom right) as defined on the software.
For copy/past don't use the mouse, use standard keyboard shorcuts.
Quote:Hi, one more point that I think I should make you aware of is that the voltage regulator does not get hot anymore as it used to, when the power supply is connected, could that be a sign that it is not working anymore ? the TX led still flashes though.
Unless you have a big fan always on (fan led must lit), the power regulator never gets hot. Please check all your solder joints, try finding any short circuit, on any defective part.
