01-01-2023, 11:04
I have been using my Weatherduino Pro2 Plus since 2018 without any issues, it has been great.
Unfortunately due to a lack of free time, I only have one TX board with temp and humidity (SHT31).
I had plans to add a second TX board for rain and wind.
And onboard the RX board I have for Temp/Humidity HTU21D and BMP180 for Barometric.
This has been working well, including with Wunderground.
Now with some free time during holidays I noticed that at some point in past year it stopped updating Wunderground.
If I restart RX, I've noticed that it gets stuck on "Gathering Data Please Wait!" although I can move past this by pressing the touch screen.
There are also three indicators on top left of screen, first is green, followed by red then yellow.
The in built web server is working OK and displaying the data from the TX and RX board.
I re-flashed both TX and RX boards (fixed a date issue mentioned in another thread).
I've tried turning on debugging but it doesn't show anything about the WU Uploading process. I'm also unsure if some of the other debug options are working.
I should also mention the TX board temp had stopped working a while ago (TMP36) so I disabled that when I re-flashed the TX firmware. So not sure if this all could be caused by a hardware issue.
I also tried moving back to V8.2 from v9.
These are the debugs I turned on.
And this is a sample of the debug output.
Cheers,
Michael
#define PRINT_DEBUG_WIFI
#define PRINT_DEBUG_NTP_UPDATE
#define PRINT_DEBUG_WU_UPLOAD
//#define PRINT_DEBUG_TS_UPLOAD
//#define PRINT_DEBUG_MYSERVER_UPLOAD
#define PRINT_DEBUG_VCHECK
#define PRINT_DEBUG_TCP_SERVER
//#define PRINT_DEBUG_AURIOL
#define PRINT_DEBUG_BIOS
#define PRINT_DEBUG_RF_MESSAGES
//#define PRINT_DEBUG_WIFI_SENSORS
#define PRINT_GENERALDEBUGAnd this is a sample of the debug output.
20:38:21.287 -> ESP8266 FW Version: WIFI GOT IP
20:38:24.287 ->
20:38:24.287 -> OK
20:38:24.287 ->
20:38:30.803 -> Mode station OK
20:38:30.803 -> Multiple mux OK
20:38:35.818 -> Join AP success!
20:38:35.818 -> Connected to AP: AT+CWJAP?
20:38:35.818 -> +CWJAP:"yarra","24:xx:xx:b5:xx:xx",11,-55
20:38:35.865 ->
20:38:35.865 -> OK
20:38:35.865 ->
20:38:35.865 -> IP Address: 172.x.x.x
20:38:35.865 -> Broadcast IP: 172.x.x.255
20:38:35.865 -> Start tcp server OK
20:38:35.959 -> STATUS:2
20:38:35.959 -> Set tcp server timout 30 seconds
20:38:36.006 -> RTC current date: Jan 01 2023
20:38:36.006 -> RTC current time: 20:38:36
20:38:36.006 -> Sending NTP request to sync clock...
20:38:36.053 -> NTP replied
20:38:36.053 -> UTC time from NTP server: 09:38:36
20:38:36.053 -> Local date set to: Jan 01 2023
20:38:36.100 -> Local time set to: 20:38:36
20:38:36.100 ->
20:38:36.100 -> RTC adjusted to local time: 20:38:36
20:38:36.147 -> RTC current date: Jan 01 2023
20:38:36.147 -> RTC current time: 20:38:36
20:38:36.147 ->
20:38:36.475 -> Checking for latest software version...
20:38:37.459 -> Latest software version: P2AT2560_RX_v9.0_b004
20:38:37.506 -> WiFi connection is ON
20:38:48.287 -> 20:38:48 - Station ID: A1 Unit ID: 0 Sensor ID: 0 Full Message: A10000,A13,1AD3,0,0,
20:39:05.293 -> 20:39:05 - Station ID: A1 Unit ID: 0 Sensor ID: 0 Full Message: A10000,A13,1AD7,0,0,
20:39:22.256 -> 20:39:22 - Station ID: A1 Unit ID: 0 Sensor ID: 0 Full Message: A10000,A19,1AD7,0,0,
20:39:39.271 -> 20:39:39 - Station ID: A1 Unit ID: 0 Sensor ID: 0 Full Message: A10000,A1A,1AD7,0,0,
20:39:56.240 -> 20:39:56 - Station ID: A1 Unit ID: 0 Sensor ID: 0 Full Message: A10000,A1A,1AD4,0,0,Cheers,
Michael
