Nice video, thanks atbukc.
That's exactly the process I use. I start by putting a point of solder at each point where I will place an SMD part, then solder it with the aid of a clamp, then when all the parts are already placed on place I solder the remaining points. Quite easy and fast.
As on the video, I also end by cleaning the PCB with a PCB cleaning product.
I use this one:
https://pt.farnell.com/kontakt-chemie/ko...dp/2142400
