Threads: 7
Weather Station: Meteo-wagenborgen.nl
In the context of CumulusMX, it has been noted that there appears to be
an issue around mDNS.
Could you shed your light on this as I suggested there that the
AQM-III should handle the mDNS requests which would solve the issue.
Could you comment on the CMX forum?
HansR
Threads: 7
(26-09-2021, 03:41)Werk_AG Wrote: Hi HansR,
Thanks for bringing my attention to this matter,and to the discussion on the CMX forum.
Isn't properly an issue, mDNS isn't implemented at all on the current AQM-III firmware, I will try to do it on next release of the AQM-III firmware.
Bellow are my comments on the CMX forum:
I will try to add mDNS procedure on next AQM-III firmware.
There is already some work done.
CumulusMX is now able to discover the device via zero-config:
Quote:2021-09-26 05:09:04.447 ZeroConf Service: Attempting to find AirLink via zero-config...
2021-09-26 05:09:04.840 ZeroConfig Service: AirLink found 'AQM-DevK1', reporting its IP address as: 192.168.1.114
2021-09-26 05:09:05.448 ZeroConf Service: Auto-discovery found the AirLink, reporting its IP address as: 192.168.1.114s
Rgs,
Thanks for the modification, I assume it will be downloadable from now on in the Downloads thread?
HansR
Threads: 336
Country:
Hi Hans,
The version with mDNS support isn't published yet. It is on a test phase now.
I will need some more time to check the implications of the changes on all WeatherDuino software.
Once published a notice will be posted on the forum.
Threads: 7
Threads: 336
Country:
WeatherDuino Air Quality Monitor III - v6.1_b008 - Release date: 2021-09-29
- Added mDNS service.
