06-09-2021, 14:09
When I point my browser to the 4pro IP all I get is 404: Not found
I can ping it ok.
Here is part of my config file.
I can ping it ok.
// Enable / Disable WiFi connection
#define ENABLE_WIFI 1 // 1= Enable WiFi connection, 0= Disable
// Broadcasting data to Wireless Display Units using WiFi
#define BROADCAST_DATA 1 // 0= Disables Data Relay, 1= Enables Data Relay
#define UDP_BROADCAST_PORT 9889 // Define the UPD broadcast port
// Enable / Disable send data to Weather Wunderground
#define ENABLE_WU_UPLOAD 0 // 1= Enable upload to Wunderground, 0= Disable
#define WU_UPLOAD_INTEMP 0 // 1= Enable upload of Inside Temperature / Humidity, 0= Disable
byte WU_upload_period = 6; // Period in minutes between uploads to WU. (Should be >= 4 minutes)
// Enable / Disable send data to WeatherCloud
// ATTENTION - You can only change the default 10 minutes interval, if you have an WeatherCloud Pro or Premium account
#define ENABLE_WC_UPLOAD 0 // 1= Enable upload to WeatherCloud, 0= Disable
#define WC_UPLOAD_INTEMP 0 // 1= Enable upload of Inside Temperature / Humidity, 0= Disable
byte WC_upload_period = 10; // Period in minutes between uploads to WC (Default for free and PLUS accounts is 10 minutes)
// Enable / Disable Air Quality send data to ThingSpeak
#define ENABLE_TS_UPLOAD 0 // 1= Enable, 0= Disable
// Enable / Disable Air Quality send data to your own server ----
// Be sure you have already created the database and table. See AirQuality_LogToSQL.php script for info
#define ENABLE_AQM_TO_MYSERVER 0 // 1= Enable, 0= Disable
// Enable / Disable internal Web Server
#define ENABLE_WEBSERVER 1 // 1= Enable 0= Disable
#define WEBSERVER_PORT 80 // WebServer port (default 80)
