[SOLVED] getting wrong time from NTP server??
I don't know what to do...   I can't get the right date from the NTP server?
I tried the reset option by long pressing the button on the pro 2 receiver.
(using the most recent version)
Any help would be appreciated!
Jk⸮⸮> ⸮⸮⸮⸮ZY0.0(Jul 14 2016 18:54:01)
SDK version:2.0.0(5a875ba)
v1.0.0.3
Mar 13 2018 09:37:06
OK
Mode station OK
Multiple mux OK
Join AP success!
Connected to AP: AT+CWJAP?
+CWJAP:"--------------","---------------",6,-59
OK
IP Address: 192.168.1.99
Broadcast IP: 192.168.1.255
Start tcp server OK
STATUS:2
Set tcp server timout 30 seconds
RTC current date & time: 156 Mar 2021 18:01
Sending NTP request to sync clock...
NTP replied
  UTC date & time from NTP server: 156 Mar 2021 17:01
RTC adjusted to local date & time: 156 Mar 2021 18:01
          Reading RTC date & time: 156 Mar 2021 18:01
System current date: 156/03/2021
System current time: 18:01:24
Checking for latest software version...
Latest software version: P2AT2560_RX_v9.0_b004
WiFi connection is ON
18:01:41 - Station ID: A1  Unit ID: 1  Sensor ID: 2  Full Message: A10012,6FA,2A4,A46,7FC,
Hi edr1924,
Please check this topic:
https://www.meteocercal.info/forum/Annou...S-Software
Then tell us if it solved the problem Cool
(05-08-2021, 00:54)Werk_AG Wrote:  Hi edr1924,
oooooooh.. I forgot to do this. Blush
This is THE proof I'm getting old...
I now added the NOTICE in the beginning of the sketch so I cannot forget it anymore!
This indeed solved the problem, thank you!!
ASCII text generator (just for fun):
https://patorjk.com/software/taag/#p=dis...OTICE%20!!
//  888b    888  .d88888b. 88888888888 8888888 .d8888b.  8888888888      888 888
//  8888b   888 d88P" "Y88b    888       888  d88P  Y88b 888             888 888
//  88888b  888 888     888    888       888  888    888 888             888 888
//  888Y88b 888 888     888    888       888  888        8888888         888 888
//  888 Y88b888 888     888    888       888  888        888             888 888
//  888  Y88888 888     888    888       888  888    888 888             Y8P Y8P
//  888   Y8888 Y88b. .d88P    888       888  Y88b  d88P 888              "   "
//  888    Y888  "Y88888P"     888     8888888 "Y8888P"  8888888888      888 888
//    Arduino IDE, from version 1.8.6 onwards is supplied with a new AVR Boards Manager,
//    which install a new compiler version (5.4.0-atmel3.6.1-arduino2).
//    Code compiled with this new compiler cause reliability problems to WeatherDuino
//    systems based on Mega and Nano microcontrollers.
//    The software compiles without any errors, but during normal use,
//    several issues will happen affecting system reliability.
//    No matter the Arduino IDE version you are using, WeatherDuino Pro2 Plus
//    software should be compiled with AVR boards manager to version 1.6.21.
//    This can easily be done, and installation is automatic.
//    Tools > Board > Boards Manager
//    Wait for downloads to finish.
//    When you move the mouse pointer over "Arduino AVR Boards",
//    you will see a "Select version" dropdown menu appear. Select "1.6.21".
//    Click "Install".
//    Wait for installation to finish.
//    Click "Close".
Wink
