UV Sensor Debug
Hi Everyone, I am currently building my setup and testing the UV sensors UVM30A and I get the message below when trying to compile, everything else is working perfectly. I am getting a voltage reading on the ADC pin of the nano, the debug works for the other sensors, any help appreciated, thanks, regards, Rob
Process_IDx:295:19: error: missing expression between '(' and ')'
#if (DEBUG_ID4)
exit status 1
Hi Rob,
Indeed there is an error on Process_IDx line 295
On line 295, just replace:
#if (DEBUG_ID4)
by
#ifdef DEBUG_ID4
Alternatively, you can download again the software package for your receiver, I already fixed the reported error.
Thank you, and sorry for this inconvenience.
Hope soon your station will have Solar Radiation and UV Index data too.
(08-03-2021, 19:31)Werk_AG Wrote:  Hi Rob,
#if (DEBUG_ID4)
by
#ifdef DEBUG_ID4
Hi Werk_AG
Thanks for that, I did manage to locate that before reading your reply which I am quite pleased with as I am still a novice when it comes to code! I have changed it and the UV reading come up in the serial monitor but still not on the compact display/cumulus, I have the following settings in the Config file -
// -------------------------------------------------------------------------------------- // WeatherDuino Pro2 Universal TX AT328 - Version: 7.0_b003 // Start of user configurable options // -------------------------------------------------------------------------------------- // -------------------------------------------------------------------------------------- // Define ID and TX unit number // -------------------------------------------------------------------------------------- #define Station_ID 0xA1 // Must be equal to your RX Unit (Value from 0x00 to 0xFF) #define Unit_ID 0 // If you use only one TX unit define it as Unit_ID = 0 // For a second TX unit, define it as Unit_ID = 1 // -------------------------------------------------------------------------------------- // Define type of Temperature / Humidity sensor used as Sensor 0 and / or Sensor 1 // -------------------------------------------------------------------------------------- #define TH_SENSOR0 1 // [SENSOR 0] - 0 for SHT2x sensor, 1 for SHT31 sensor, 2 for HTU21 sensor, 9 for Not Used #define TH_SENSOR1 9 // [SENSOR 1] - 0 for SHT1x sensor, 1 for DHT22 sensor, 9 for Not Used // -------------------------------------------------------------------------------------- // Define which Temp / Hum sensor controls the RS fan, and threshold values // -------------------------------------------------------------------------------------- #define FANCONTROL_SENSOR 0 // 0 for Sensor 0, 1 for Sensor 1 (which sensor is used to control the RS Fan) const int fanOn_HiTemp = 19; // RS Fan turn on when outside temperature is >= than this value (ºC) const int fanOn_LowTemp = 2; // RS Fan turn on when outside temperature is <= than this value (ºC) const int fanOn_LowWind = 1; // RS Fan turn on when Wind Average is <= than this value (m/s) // -------------------------------------------------------------------------------------- // Define type of Wind Speed sensor. See below for allowed types // -------------------------------------------------------------------------------------- /* --- Fine Offset Anemometers --- Use 1O for standard FO anemometers Use 11 for FO anemometer modified with 1 hall effect sensor --- Inspeed Anemometers --- Use 20 for Inspeed Vortex, digital 8 pulse revolution anemometer Use 21 for Inspeed Vortex, hall efect sensor Use 22 for Inspeed Vortex, read switch sensor --- Davis Anemometers --- Use 30 for Davis 6410, 7911 anemometer --- Novalynx Anemometers --- Use 40 for Novalynx, model 200-WS-02F --- Environmental Measurements Limited --- Use 50 for EML, model WSD1 --- Didcot Instrument Company --- Use 60 for DIDCOT, model DWR205 --- Vector Instruments --- Use 70 for Vector Instruments model A100LK Use 71 for Vector Instruments model A100L2 Use 72 for Vector Instruments model A100R */ #define WINDSPEED_SENSORTYPE 10 // SEE INFO ABOVE!!! // -------------------------------------------------------------------------------------- // Define type of Wind Direction sensor // -------------------------------------------------------------------------------------- /* --- Fine Offset Wind Vane --- Use 1O for standard FO wind vane --- Analogue Wind Vanes --- Use 20 for any 5V analogue wind vane. See bellow for a list of tested models - Inspeed E-Vane 2 - Davis 6410 - Novalynx, model 200-WS-02F - Environmental Measurements Limited, model model WSD1 - DIDCOT, model DWD205 - Almost all 5V analogue wind vanes will work */ #define WINDDIR_SENSORTYPE 10 // SEE INFO ABOVE!!! // -------------------------------------------------------------------------------------- // Analogue Vane Offset Calibration // -------------------------------------------------------------------------------------- const int WDir_offs = 0; // Usually there is no need to change default value (zero) // -------------------------------------------------------------------------------------- // Define Rain Gauge tip boucket value (mm) // -------------------------------------------------------------------------------------- /* Use 0.280 for standard FineOfset rain gauges (Datasheet value = 0.2794) Use 0.200 for standard metric Davis rain gauges Use 0.254 for standard imperial Davis rain gauges */ #define COLLECTOR_TYPE 0.280 // Please note: Values must be in metric units. Max. resolution: 3 decimal digits // -------------------------------------------------------------------------------------- // Define type of UV Sensor // -------------------------------------------------------------------------------------- #define UV_SENSOR 0 // 0= UVM-30A, 1= VEML6075, 9= Not used // -------------------------------------------------------------------------------------- // Soil / Leaf Interface Enable Disable // -------------------------------------------------------------------------------------- #define SOILLEAF_INTERFACE 0 // 0 = Soil Leaf Interface not used, 1 = Enable Soil Leaf Interface const byte Number_AnalogSensors = 2; // Up to 4 analog sensors // -------------------------------------------------------------------------------------- // Define which data this unit will send. 0 = Not send this data, 1= Send this data // -------------------------------------------------------------------------------------- #define ID0 1 // Temp/Hum Data #define ID1 0 // Not Used #define ID2 1 // Wind data #define ID3 1 // Rain data #define ID4 1 // SolRad / UV data #define ID5 1 // Hardware Status - System Temp, Battery Voltage etc #define ID7 0 // Send Soil & Leaf Temperature Data #define ID9 0 // Send Soil & Leaf Moisture / Wetness Data // -------------------------------------------------------------------------------------- // VBat voltage fine tune (values in Volt, positive or negative) // -------------------------------------------------------------------------------------- #define VBAT_OFFSET 0.0 // // ************************************************************************************* // Hardware Settings // ************************************************************************************* // Define if the TMP36 sensor is instaled #define USE_TMP36 1 // 0= Not Instaled, 1= Intalled // -------------------------------------------------------------------------------------- // SHT31 I2C Address - Default address will work most of the times! // -------------------------------------------------------------------------------------- #define SHT31_ADDRESS 0x44 // Default value is 0x44, but it can be changed to 0x45 // -------------------------------------------------------------------------------------- // Debug // -------------------------------------------------------------------------------------- //#define ENABLE_DEBUG //#define DEBUG_ID0 //#define DEBUG_ID2 //#define DEBUG_ID3 //#define DEBUG_ID4 //#define DEBUG_ID5 //#define DEBUG_SLINTERFACE //#define EASYWEATHER_TEST // --------------------------------------------------------------------------------------------------- // End of user configurable options // ---------------------------------------------------------------------------------------------------
Rob
Hi again
I have sorted it out now, I forgot to change the settings in the receiver config file  Big Grin Sleepy
​​​​​​​Rob
I just can say that you are going pretty, pretty well. Like
Those initial "troubles" are normal until you get familiar to the several WeatherDuino config options.
For any doubt, I will be here.
