WD Software_latest release
When compiling the software I get the following error, could you please advise
  Arduino: 1.8.12 (Windows 10), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600" C:\Users\barro\Documents\Arduino\WeatherDuino_4PESP8266_WD_v5.3_b001\WeatherDuino_4PESP8266_WD_v5.3_b001.ino: In function 'void loop()': WeatherDuino_4PESP8266_WD_v5.3_b001:407:12: error: 'class TFT_eSPI' has no member named 'getTouch'     if (tft.getTouch(&t_x, &t_y))             ^ exit status 1 'class TFT_eSPI' has no member named 'getTouch' This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
(10-04-2020, 07:36)Barrow4491 Wrote:  When compiling the software I get the following error, could you please advise
My apologies all good, changed the eSPI library to eSPI-1.4.8 (had multiple libraries and used the incorrect one)
