Problem verifying TX software
Question
I seem to have a lot of time on my hands at present (because of some little bug!) so I'm finally getting back to my WeatherDuino, but I'm having problems because I have a very bad memory!! Confused
TX board is V3.12
I updated my version on Arduino IDE to 1.8.12 and I downloaded and opened the WeatherDuino_Pro2_Universal_TX_V7.0_b002. When I try to do the verify, I get the following error message:
Arduino: 1.8.12 (Linux), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600" /home/gord/Arduino/libraries/DHTxx/DHTxx.cpp:6:25: fatal error: util/atomic.h: No such file or directory  #include <util/atomic.h>                          ^ compilation terminated. exit status 1 Error compiling for board LOLIN(WEMOS) D1 R2 & mini.
So I created a directory in /home/gord/Arduino/libraries/DHTxx called util and copied the file called atomic.h to that new directory. Now when I do the verify I get the following error message:
Arduino: 1.8.12 (Linux), Board: "LOLIN(WEMOS) D1 R2 & mini, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600" /home/gord/Arduino/WeatherDuino_Pro2_Compact v3/software/TX software/WeatherDuino_Pro2_Universal_TX_v7.0_b002/WeatherDuino_Pro2_Universal_TX_v7.0_b002.ino: In function 'void setup()': WeatherDuino_Pro2_Universal_TX_v7.0_b002:302:3: error: 'DDRB' was not declared in this scope    DDRB  = DDRB | B100000;        // pinMode(13, OUTPUT); - Led on Pin D13    ^ WeatherDuino_Pro2_Universal_TX_v7.0_b002:303:14: error: 'PORTB' was not declared in this scope    setPortLOW(PORTB, 5);          // digitalWrite(13, LOW);               ^ /home/gord/Arduino/WeatherDuino_Pro2_Compact v3/software/TX software/WeatherDuino_Pro2_Universal_TX_v7.0_b002/WeatherDuino_Pro2_Universal_TX_v7.0_b002.ino:68:33: note: in definition of macro 'setPortLOW'  #define setPortLOW(port, pin) ((port) &= ~(1 << (pin)))                                  ^ WeatherDuino_Pro2_Universal_TX_v7.0_b002:304:3: error: 'DDRD' was not declared in this scope    DDRD = DDRD | B100000;         // pinMode(FAN_PIN, OUTPUT); - Fan Pin D5    ^ /home/gord/Arduino/WeatherDuino_Pro2_Compact v3/software/TX software/WeatherDuino_Pro2_Universal_TX_v7.0_b002/Process_IDx.ino: In function 'void send_SensorID0()': Process_IDx:49:17: error: 'PORTD' was not declared in this scope      setPortHIGH(PORTD, 5);           // digitalWrite(FAN_PIN, HIGH);  // Turn FAN power (Pin D5) ON                  ^ /home/gord/Arduino/WeatherDuino_Pro2_Compact v3/software/TX software/WeatherDuino_Pro2_Universal_TX_v7.0_b002/WeatherDuino_Pro2_Universal_TX_v7.0_b002.ino:67:34: note: in definition of macro 'setPortHIGH'  #define setPortHIGH(port, pin) ((port) |= (1 << (pin)))                                   ^ Process_IDx:54:16: error: 'PORTD' was not declared in this scope      setPortLOW(PORTD, 5);            // digitalWrite(FAN_PIN, LOW);  // Turn FAN power (Pin D5) OFF                 ^ /home/gord/Arduino/WeatherDuino_Pro2_Compact v3/software/TX software/WeatherDuino_Pro2_Universal_TX_v7.0_b002/WeatherDuino_Pro2_Universal_TX_v7.0_b002.ino:68:33: note: in definition of macro 'setPortLOW'  #define setPortLOW(port, pin) ((port) &= ~(1 << (pin)))                                  ^ /home/gord/Arduino/WeatherDuino_Pro2_Compact v3/software/TX software/WeatherDuino_Pro2_Universal_TX_v7.0_b002/Process_IDx.ino: In function 'double get_WindVane()': Process_IDx:144:17: error: 'PORTD' was not declared in this scope      setPortHIGH(PORTD, VANEPOWER_PIN);    // digitalWrite(VANEPOWER_PIN, HIGH); - Vane power Pin D4                  ^ /home/gord/Arduino/WeatherDuino_Pro2_Compact v3/software/TX software/WeatherDuino_Pro2_Universal_TX_v7.0_b002/WeatherDuino_Pro2_Universal_TX_v7.0_b002.ino:67:34: note: in definition of macro 'setPortHIGH'  #define setPortHIGH(port, pin) ((port) |= (1 << (pin)))                                   ^ WeatherDuino_Pro2_Universal_TX_v7.0_b002:77:22: error: 'A3' was not declared in this scope  #define VANE_PIN     A3                       ^ /home/gord/Arduino/WeatherDuino_Pro2_Compact v3/software/TX software/WeatherDuino_Pro2_Universal_TX_v7.0_b002/Process_IDx.ino:146:16: note: in expansion of macro 'VANE_PIN'      analogRead(VANE_PIN);                // Do 1 reading to stabilize ADC                 ^ /home/gord/Arduino/WeatherDuino_Pro2_Compact v3/software/TX software/WeatherDuino_Pro2_Universal_TX_v7.0_b002/Process_IDx.ino: In function 'void send_SensorID5()': WeatherDuino_Pro2_Universal_TX_v7.0_b002:76:22: error: 'A2' was not declared in this scope  #define BATVOLT_PIN  A2                       ^ /home/gord/Arduino/WeatherDuino_Pro2_Compact v3/software/TX software/WeatherDuino_Pro2_Universal_TX_v7.0_b002/Process_IDx.ino:339:16: note: in expansion of macro 'BATVOLT_PIN'      analogRead(BATVOLT_PIN);                 ^ /home/gord/Arduino/WeatherDuino_Pro2_Compact v3/software/TX software/WeatherDuino_Pro2_Universal_TX_v7.0_b002/Routines.ino: In function 'void sendData(int, long int, long int, long int, long int)': Routines:144:15: error: 'PORTD' was not declared in this scope    setPortHIGH(PORTD, 7);                                // digitalWrite(TX_PTT_PIN, HIGH); - Turn on power to TX module. Pin D7                ^ /home/gord/Arduino/WeatherDuino_Pro2_Compact v3/software/TX software/WeatherDuino_Pro2_Universal_TX_v7.0_b002/WeatherDuino_Pro2_Universal_TX_v7.0_b002.ino:67:34: note: in definition of macro 'setPortHIGH'  #define setPortHIGH(port, pin) ((port) |= (1 << (pin)))                                   ^ exit status 1 'DDRB' was not declared in this scope
I know I must be doing something wrong but I can't see what.
Any help appreciated,
Gord
Think you selected the wrong board - WeMos instead of Nano.
(24-03-2020, 23:08)WetCoast Wrote:  Any help appreciated,
Gord
Hi Gord,
As Engolling said, on boards select Arduino Nano, and on Processor select ATmega 328P (old bootloader)
You are absolutely correct, if I change the board to "Android Nano" it works perfectly!!
I must try to remember:
Android Nano for the TX board
LOLIN(WEMOS) D1 R2 & mini for the RX board Thanks very much, Gord
