Threads: 15
Country:
Hi Werk
Does the AQM II require the RF module to transmit to a receiver such as the Pro2 Compact, or does that occur via the wifi udp stream?
Many thanks
Colin
Threads: 336
Country:
Hello Colin,
Currently yes.
At some point in the future that feature may be added into the Pro2 Compact receiver software.
Werk_Ag
Threads: 15
Country:
Ok, no problem at all
I'm going to look at retrofitting my existing AQM with a Wemos to take advantage of the wifi. I have devised a method to send the AQ data to Weewx using UDP. The code is currently running on the receiver but I could easily move it to the AQM with the Wemos. They are $10 NZ each, so easy to buy and have a play with.
Many thanks
Colin
