Problems compiling latest version of Pro2 Plus Rx Software
Hi All,
I've just downloaded the latest version of the Pro2+ Rx software (P2AT2560_RX_v8.1_b002) and libraries, but i'm not able to compile it and get a few errors. The errors are below and I've attached the verbose output from the Arduino IDE during compilation. Has anyone else had these errors, or am I doing something simple wrong?
Thanks in advance for your help!
Zak
Arduino: 1.8.8 (Windows 10), Board: "Arduino Nano, ATmega328P" WeatherDuino_P2AT2560_RX_v8.1_b002:428:14: error: 'Serial1' was not declared in this scope  ESP8266 wifi(Serial1);               ^ Y:\Zak's Documents\Electronics\Arduino Projects\WeatherDuino\WeatherDuino_Pro2_PLUS\software\RX software\WeatherDuino_P2AT2560_RX_v8.1_b002\Routines.ino: In function 'void B_doubleclick()': Routines:629:14: error: 'PORTH' was not declared in this scope    setPortLOW(PORTH, 6); //digitalWrite(TFT_BKL, LOW);               ^ Y:\Zak's Documents\Electronics\Arduino Projects\WeatherDuino\WeatherDuino_Pro2_PLUS\software\RX software\WeatherDuino_P2AT2560_RX_v8.1_b002\WeatherDuino_P2AT2560_RX_v8.1_b002.ino:129:33: note: in definition of macro 'setPortLOW'  #define setPortLOW(port, pin) ((port) &= ~(1 << (pin)))                                  ^ Y:\Zak's Documents\Electronics\Arduino Projects\WeatherDuino\WeatherDuino_Pro2_PLUS\software\RX software\WeatherDuino_P2AT2560_RX_v8.1_b002\VP.ino: In function 'void cmdDmpaft()': VP:292:19: error: 'PORTG' was not declared in this scope        setPortHIGH(PORTG,  1); //digitalWrite(FLASH_CS, HIGH);                    ^ Y:\Zak's Documents\Electronics\Arduino Projects\WeatherDuino\WeatherDuino_Pro2_PLUS\software\RX software\WeatherDuino_P2AT2560_RX_v8.1_b002\WeatherDuino_P2AT2560_RX_v8.1_b002.ino:130:34: note: in definition of macro 'setPortHIGH'  #define setPortHIGH(port, pin) ((port) |= (1 << (pin)))                                   ^ VP:306:14: error: 'PORTG' was not declared in this scope   setPortHIGH(PORTG,  1); //digitalWrite(FLASH_CS, HIGH);               ^ Y:\Zak's Documents\Electronics\Arduino Projects\WeatherDuino\WeatherDuino_Pro2_PLUS\software\RX software\WeatherDuino_P2AT2560_RX_v8.1_b002\WeatherDuino_P2AT2560_RX_v8.1_b002.ino:130:34: note: in definition of macro 'setPortHIGH'  #define setPortHIGH(port, pin) ((port) |= (1 << (pin)))                                   ^ exit status 1 'Serial1' was not declared in this scope
Hello Zak,
I'm afraid you are trying to compile the code for the wrong board.
The Pro2+ software is for a Mega 2560.
Smile
(05-02-2019, 13:58)Werk_AG Wrote:
(05-02-2019, 10:56)Zack_ster Wrote:  Zak
Hello Zak,
Doh! - as Homer Simpson would say. Thank you!
