Threads: 15
10-01-2019, 04:18
(This post was last modified: 10-01-2019, 04:21 by
41south.)
Strange, it's definitely in there. I'm about to do the update so will see after that
Edit: Whoops, there's no update for the Pro2 compact so I won't do that
const char* WeatherStation_Name = "41south"; // Put here your Weather Station name or Location name - DON'T LEAVE EMPTY
const char* WeatherStation_URL = "http://41south.net.nz"; // If you have an URL to your Meteo Website put it here (can be the WU URL). URL should start with http or https
Threads: 15
10-01-2019, 04:36
(This post was last modified: 10-01-2019, 04:38 by
41south.)
Can you confirm that the lat/lon should be 3 decimal places or 5? I see mine is a little out so I will update it
- Precision of the Latitude and Longitude data has enhanced from 3 to 5 decimal places (thanks t3gathome for your research on this).
but in the code it says
// Put here your Station latitude in degrees North (always use 3 decimal places)
And this station [[2019-01-01 01:04:31 Lisbon time] Device Type: P2AT2560RX] is now replaced so can be removed (or will it just remove itself over time?
Threads: 15
Excellent, sorted, thanks.
Did you see anything I need to change in my url for it to show? Or is it possibly because there are 2 stations showing?
It is listed now.
No problem with having two or more weather station on the same location. Each one can have the same or a different name and URL.
Indeed as we can see on the map, there are some users with two WeatherDuino weather stations on the same location.
