Hello everybody,
Finally it's the time to release the first (beta) version for the WeeWx WeatherDuino Logger plugin.
This plugin for WeeWx allows you to get all extra data like snow height, AQM data or any extra sensors in full precision to WeeWx weather software.
![[Image: y4mj7v7r65wBJP5QK31hcW2xVDKwW6Z-tDctpNcs...pmode=none]](https://ptvjiw.db.files.1drv.com/y4mj7v7r65wBJP5QK31hcW2xVDKwW6Z-tDctpNcshAoXmfjvhRi-hyh679y2gNOYk7D218KS1baUidQvV8HXxt6xjzM40Q4PKachDzcapmSk4qTF7f_is45d871mblT2XM3ZImvxwXBvjetcBMWpcIh2jS-01PWIxLndVNNzub1hB-XFy1t8RAaBFswiOTAuHU6HlvvHJA7FJ-gfE-w4swn6w?width=499&height=177&cropmode=none)
The principle is very easy, the WeatherDuino logger plugin writes each minute a WeeWx export text file with your desired values. The WeeWx plugin reads this file, checks its currency, and saves it to the WeeWx database.
Attention: The plugin was tested with the Database to use metric units, it should also work with a database in US units (default), but I have not tested it yet.
Please read the included manual carefully. Since the plugin is in a beta stadium, all preconditions have to be like in the test environment, otherwise WeeWx might crash.
Don't forget to make some backups before
Find the latest release and the install manuals in my git:
https://github.com/menachers/WeatherDuino
Best regards,
Best regards,
