Threads: 15
Country:
My initial thought was to replace one resistor with a 10/20 turn pot, one of the small blue ones. Then use that to set the correct divider with a multimeter.
I may go that way to begin with, then I have solved the problem as it was designed pretty much
Threads: 336
Country:
Hello Alan,
I agree that it will be more logical to "tweak" a VBat value in the Transmitter software, specially because, as you said, it also covers the use of more than one Transmitter.
Doing it doesn't seem difficult, but the changes should be done in both the TX and RX software, what would imply that users will need to upgrade RX and TX units. Well, I liked the idea, so I will gonna work on it for upcoming software release.
UPDATE:
It's already done, and under test! For now is working like a charm.
To avoid that all users had to upgrade the TX software (its winter in some places of the globe) to use any new RX software version, a new setting was added on the Config_Options.h file.
